b16a eg wont go pass 3000rpm!
Old May 14, 2010 | 12:20 PM
EGFLASH's Avatar
Default b16a eg wont go pass 3000rpm!
ok so i had a code for a bad icm replaced my bad icm... now im gettin i misfire around 3000rpm and it wont let me go past it! and my stock tach gauge jumps like crazy now! i took my dizzy out and i seen that i have alot of endplay on the dizzy shaft would this be the problem??? also changed my computer and still does it. its a stock b16a into my eg. lmk wat u guys think it would help alot thanx!!!
Old May 14, 2010 | 12:26 PM
Ef8crxsi4u2nv's Avatar
Default Re: b16a eg wont go pass 3000rpm!
Kinda sounds like your car is in Limp mode. Do you have a CEL? What Ecu is in there now?
Old May 14, 2010 | 12:30 PM
EGFLASH's Avatar
only code is 41 which is o2... im using a p30 and used my friends p30 samething and even used a p06 i had lying around samething
Old May 14, 2010 | 12:33 PM
EGFLASH's Avatar
its like its back firing went it up to 3000rpm... and car is idle rough sounds like i got stage 3 cams lol
Old May 14, 2010 | 12:55 PM
300whpej's Avatar
vss hooked up and working properly?
Old May 14, 2010 | 01:55 PM
EGFLASH's Avatar
yep i thought it was that too but mines was brand new when i put my tranny in put a soch vss which i think is the same and samething.. i did paint the tranny ima sand the part of it where the ground goes maybe cause the paint the connection is bad but right now i jus want it too run right then ill figure that out
Old May 15, 2010 | 02:46 PM
EGFLASH's Avatar
ttt
Old May 15, 2010 | 03:28 PM
xxstuntin4life's Avatar
sounds like a bad tps sensor.. i had the same prob on my 93 coupe with a b16 in it..
also fix that code 41, i was throwing that code for a while and it made my car run like ***
Old May 15, 2010 | 03:37 PM
EGFLASH's Avatar
i will try i got another one lying around
Old May 15, 2010 | 03:52 PM
EGFLASH's Avatar
at idle car sounds strong now sometimes idle is rough.. motor feels strong till 3000rpm
Old May 15, 2010 | 06:53 PM
REDEM1FTW's Avatar
Icon3 Re: b16a eg wont go pass 3000rpm!
check dizzy and dizzy wiring. friend had same problem in his b16 integra and it ended up being a wire that came lose on his distributor harness
Old May 15, 2010 | 07:03 PM
SLURS's Avatar
bump
Old May 15, 2010 | 08:26 PM
BRP_TX's Avatar
Just check wires, I had an eg b20 swap that did the same thing. All it turned out to be was a chaffed wire
streethondar
Sep 14, 2012 12:50 PM
jayeghatch
Sep 12, 2012 07:28 PM
EGFLASH
Jun 9, 2010 06:18 PM
dohctor_B
May 4, 2006 06:32 AM
pelotudo
Feb 8, 2002 09:27 AM
