****** POST ALL YOU B SERIES TURBO BUILDS IN THE UK!*******
As stated i want to see all the turbo builds in the UK, im unsure of how many there are so im hoping this will show me a few! ill start, il been building my car for just under a year now, nearly done..
B18c4 with 83mm bore
type R head
darton steel liners
cp 8:5:1 pistons
eagle steel rods
garrett GT35r duel ball bearing beast
sfab top mount manifold
tial 38mm external wastegate
hondata s300 with the pwm components in to run boost by gear (also have mac solenoid)
1000cc bosch ID's
edelbrock victor x inlet manifold
omni power 70mm throttle body
brian crower custom made camshafts
brian crower titanium valve springs and retainers
brian crower nitride coated vlaves
3'' ally mandrel bent boost pipes
huge front mount
this is going in an ek4 civic, get posting then people!
type R head
darton steel liners
cp 8:5:1 pistons
eagle steel rods
1000cc bosch ID's
huge front mount
made from a blank shaft, my engine builder gave B/C the specs and they made them for me. The specs have been tried a few times with amazing results.
my daily driver...
B18c4
cp pistons
eagle rods
ARP headstuds
knockoff skunk2 intake manifold
Pfab ramhorn
garrettt t3t04e .57 trim
tial 38mm gate + tial Q bov
rc550 injectors
mapped with ectune.
made 406hp at 10psi and 283lbft
B18c4
cp pistons
eagle rods
ARP headstuds
Pfab ramhorn
rc550 injectors
mapped with ectune.
400bhp on 550cc injectors... someone correct me if im wrong but you cant get 400bhp on 550cc injectors? also a question for all you americans.... does your bhp read higher over there than over here, say a car over there was 400bhp, would it be 400bhp over here, i heard there numbers vary from country to country.
B16 83mm
Benson sleeved
Benson Crank
Pauter rods
Cp pistons
Acl bearings
Type r oil pump
Steel flywheel
Arp stud and nut kit
Arp flywheel bolts
Aeromotive fpr
-6 fuel and return lines
Bosch 044 fuel pump
Rc 1000cc injectors
Bdl 74-72mm throttle
Full race prostreet exhaust mani
Tial 44mm wastegate
-10 breather hoses
Still need a few bits and pieces to finish the build cams, turbo etc
Benson sleeved
Benson Crank
Pauter rods
Cp pistons
Acl bearings
Type r oil pump
Steel flywheel
Arp flywheel bolts
Aeromotive fpr
Bosch 044 fuel pump
Rc 1000cc injectors
Tial 44mm wastegate
-10 breather hoses
