Weird oil leak
Old May 13, 2010 | 09:50 PM
Mentat Ghola's Avatar
Default Weird oil leak
My 98 GSr will consume roughly 1qt every 3k miles. But I recently noticed a slight oil leak, very small. If its parked overnight in the morning there was a small stain on the ground.
Then, I topped off my oil to full capacity, and noticed that the oil leak stopped.
So - it leaks when my oil level is low, but not when its at capacity.
Whats leaking here?
Old May 13, 2010 | 10:02 PM
91_LS's Avatar
Default Re: Weird oil leak
Whats leaking here?
The leek might be stopping because the car is not running. Id check the oil drain plug and all around the oil pan. Also check the cam gear plug by the dizzy. You might also have a leaky oil filter or loos censer on the back of the block. Take your time and look/investigate.
stephie1love
Aug 25, 2014 04:01 AM
EGgoJDM
Dec 1, 2009 12:05 PM
pjr710
Feb 6, 2009 10:23 AM
DO_ITR_YoungD_19
Honda S2000
11
Nov 24, 2008 08:38 PM
DAintegraGSR
Apr 28, 2005 08:22 PM
