speedometer!! help
Old May 13, 2010 | 01:43 PM
jdm.coupe3234's Avatar
Default speedometer!! help
ok so lastnight i finished swapping the d15b7 into my eg, i drove it around for like an hour and it drove fine. then this morning when i went into work (dominos pizza) and on my first delivery my speedometer started fluctuating up and down.. it did it for the next few deliveries.. then it stoppd for a while.. then came back.. and after going aboove 35 mph the speedo will just drop to zero and every once in a while it will pop back up.. anyone know what the problem could be?
Old May 13, 2010 | 01:49 PM
Ef8crxsi4u2nv's Avatar
Default Re: speedometer!! help
Check all your connections, Vss, Battery, Alternator, Grounds
Old May 13, 2010 | 02:37 PM
mikej94civex's Avatar
i posted a thread on here....search bro!!!
https://honda-tech.com/forums/showth...speedo+problem
Old May 13, 2010 | 02:38 PM
if checking the ^ mentioned parts did not work..do what i did...but if u nvr swapped the cluster out i'm sure it's just in the vss on the swapped tranny
Old May 13, 2010 | 02:41 PM
Agreed. Check the vss
Old May 13, 2010 | 11:36 PM
lol it just ended up being a ground wire.. i forgot to ground the wire that goes on top of the valve cover to the frame part next to the driver side headlight lol. i feel like a retard
Old May 14, 2010 | 06:08 AM
Haha it's the simplest little things that get the best of us
hbhonda
15
Feb 2, 2010 05:02 PM
ULTRAdC2
Feb 1, 2007 05:27 PM
96b18c
Jun 3, 2004 07:29 PM
CivicBoi
Feb 21, 2004 02:00 PM
PSU
May 22, 2002 07:18 PM
