Speedometer?
Re: Speedometer? (DxHatchback)
mine does the same thing. my friend told me that it could be one of three things. the gears are busted, the ground is loose, or the wire isnt making full contact. you changed the wire right? so check the ground, it could be loose. if not that, check the gears. mine is rom the wire. it only works if its hot outside, it doesnt work during cold weather. go figure...
