What clutch to handle forced induction
Old May 13, 2010 | 10:34 AM
low91rex's Avatar
Default What clutch to handle forced induction
Whats up ht just wondering If anyone can help me figure out what clutch would be right for my setup. I have a high compression B18B and b16 lsd tranny, the car has an off brand stage 3 clutch which was destroyed last weekend after some hard launches.
In about a month I have a turbo setup w/ an HX35 i put together that Im putting on. Motor will have srp pistons and eagle rods. Power goals are 350 plus HP. Untill i get my beater going I have to still drive this car.
Question is what brand clutch would be able to handle 350-400HP? I was looking into comp clutch stage 4: http://cgi.ebay.com/ebaymotors/Compe...#ht_2777wt_939
After some reaserch I heard they like to scratch at high rpm shifts.
My budget is somewhat tight being i just bought all my internals.
any suggestions would be great thanks.
Old May 13, 2010 | 11:01 AM
Just a n00b's Avatar
Accident Prone
Default Re: What clutch to handle forced induction
i heard CC is terrible, and wont last for more than like 2 months or something like that. people often say go with exedy clutches. i wouldnt know which stage, but i know that CC is bad.
Old May 13, 2010 | 02:16 PM
same ol Steve's Avatar
Figure how much torque you will be making and buy your clutch based on that not hp.if you look at the clutch companies websites they rate them on torque numbers.
See if you can find dyno charts of a similar setup to what yours will be and go from there.
Old May 13, 2010 | 02:29 PM
sanman000719's Avatar
excedy hyper single
Old May 13, 2010 | 02:56 PM
PaddingtonBear's Avatar
lol @ heresay
Old May 13, 2010 | 05:55 PM
low91rex's Avatar
When I was shopping around I saw they usually rated them by percentage over stock. On ebay theres a cc stage 5 4 puck for $354. It says It can handle 300% over stock. That should be good right? Any one have first hand experience on them?
What clutch are you running on your FI setups?
Old May 13, 2010 | 05:57 PM
90blackcrx's Avatar
I'd suggest running an exedy.
Old May 13, 2010 | 06:25 PM
nicefighter80's Avatar
I prefer the CC the guy above, who bashed them, prolly has never even owned one and just thread surfs all day. local shop uses CC stage 5 in every single one of there turbo cars, i personally use a CC stage 2
Old May 14, 2010 | 04:13 AM
90teg's Avatar
That local shop probably does not race at the track with that clutch. Why don't you research before you praise that clutch.
To the OP if it's just a street car that will never see the track the CC clutch will hold up fine. But if go the the track you will have problems miss shifting and the clutch probably will not last. Do a search, I am not the only one that hate's CC for track use. I had three go bad on a b-series(two in one month!) and one on a H-series.
Old May 14, 2010 | 11:35 AM
90blackcrx's Avatar
We've had a ton of issues with CC clutches ( mostly on K setups ) , we've installed a good amount, and now if a customer ask to use a CC clutch or brings one in for an install, it comes with a warning.
Old May 14, 2010 | 12:13 PM
AlexDphoto's Avatar
Im on a competition stage 5 only issue i had was a throwout bearing, other than that good ****!
Old May 14, 2010 | 12:17 PM
Im on a competition stage 5 only issue i had was a throwout bearing, other than that good ****! @ what power level??????????
Old May 14, 2010 | 01:19 PM
AlexDphoto's Avatar
Right now im only at 293/211 but im going to be turning the boost up after import alliance.
im going to do 14-16psi on my Gt3255E and E85, im hoping for somewhere around 400whp/250+wtq. I just dont wanna have to drive to TN on E85, searching for stations will suck, so im going to keep it pump gas until after july
I went with the stage 5 just in case i decide to sleeve and go big turbo next year.
And the throwout bearing issue was a whirring sound, it didnt actually go out. I took my transmission off and replaced it just in case though. Cheap fix really
Old May 14, 2010 | 01:21 PM
yeah that clutch seems to be good for that
the people I have seen not liking the cc clutch is the ones over 500hp/350lb tq
Old May 14, 2010 | 01:24 PM
AlexDphoto's Avatar
I went with stage 5 over 4 because they were the same price, and id rather over do my clutch than under. Took a little getting used to but so far i love it.
Old May 14, 2010 | 01:39 PM
For one, they do use it at the track, built b-series making over 500 whp in one car and the other one I am unsure of.
For second, have you ever thought maybe you cant drive? I mean who breaks 2 clutchs in one month
Old May 14, 2010 | 01:49 PM
AlexDphoto's Avatar
Yeah its kind of weird 2 brand new clutches would just take a **** like that. I know plenty of people running CC clutches with very little to no issues.
Old May 16, 2010 | 09:16 AM
dantamparacer's Avatar
I have a competition clutch "stage 5" sprung. It works great for me. I make 380whp and beat on it every weekend. Never had a problem with it. I have had it in since Feb 2008 and still going strong so far. The car is getting retuned for more boost and e85 probably gonna be around 450whp so we will see what happens then.
Old May 16, 2010 | 04:29 PM
AlexDphoto's Avatar
Very nice ^^ I cant wait to up the boost on my car!
Old May 16, 2010 | 06:47 PM
I kills me though what makes a stage 4 different from a stage 5? Is it just a name to make it sound great? What about ACT are there "stages" identical to cc? Its just something to think about
Old May 17, 2010 | 10:15 PM
taylorvw's Avatar
has anyone here had any experience with yonaka clutch's? in particular the 6 puck?
Old May 18, 2010 | 06:35 AM
90teg's Avatar
You don't have any personnel experience so there I'm not even going to comment farther. If I was the only person this has happened to then maybe I'd say it was my fault. But many people has this issue. Only thing I changed in my car was the clutch and ran 10.9 Ran it for a year with no issues I had with that CC.
Old May 18, 2010 | 02:23 PM
Slo-mo's Avatar
I like action clutch's. I have the 1MS kit and its pretty cool. I have friends using the 2MS kit cause it handles more power and they havent had any problems with them.
Bonestock98GS
Dec 6, 2009 12:19 PM
Jay_Sensing
Oct 16, 2005 08:44 PM
123Four
Apr 20, 2004 07:33 AM
b00stn
Nov 4, 2002 07:10 PM
