CRX lowering springs.... HELP
Old May 12, 2010 | 10:46 PM
ft541's Avatar
Default CRX lowering springs.... HELP
Ok so i bought a 90 crx and its lowered on coil overs i believe and rides hella bouncy. I dont have money right now to buy all new struts i jus wanna know if some good lowering springs would give a better ride then wat it is. ill be useing the stock struts help me out let me know wat u have and some pics if u got em see how ur cars stance!
heres mine sitting kinda low
Old May 13, 2010 | 03:45 AM
Joay's Avatar
Default Re: CRX lowering springs.... HELP
If it hits really hard when you go over a bump, then your spring rates are probably pretty stiff and getting softer ones will help it ride better. If the whole car bounces a little bit after you go over a bump, then your shocks are blown and need to be replaced.
Old May 13, 2010 | 07:16 AM
scottmog's Avatar
the lower you go the stiffer you need the springs to be
the struts also provide cushion, dont be a usual cheap hondatech member, do it right.
spend 800 bucks and get konis and ground control. all your problems will be gone.
u probbly bought some cheap *** ebay coilovers... u get what you pay for
Old May 13, 2010 | 07:31 AM
ft541's Avatar
I didnt buy any thing i jus bought the car the way it is. And i dont really want to spend 800 on suspension i might not evan keep it. So is there any good springs u guys recommend???????? let me know
Old May 13, 2010 | 07:39 AM
Joay's Avatar
If your struts are done then new springs won't help the bounce much. If they're just old and tired, stiffer springs will make them work harder to dampen the shock, so soft springs might make it a little better. Eibach Sportlines are fairly soft for aftermarket, or you could get some OE springs which are really soft.
92teginsc's Avatar
i have some.
Old May 13, 2010 | 07:55 AM
ft541's Avatar
ok any other options? do u know any body selling any on here?
Old May 13, 2010 | 08:02 AM
4crx4me's Avatar
H&R 51807-55. OE Sport Springs. Somewhere around $170 from King MotorSports. And a set Tokico Illumina shocks. You can find em on ebay for around $350. Only get Illuminas, don't bother with the blue Tokico HP's they're junk.
I've had them in my 90 Si for a couple years, now. With no complaints.
91efbluehatch's Avatar
why replace the springs, when you need new shocks.
The ride wont be any better and it would be wasted money.
Just my $.02.
Old May 13, 2010 | 08:05 AM
ft541's Avatar
the shocks seem fine they not leaking grease or nothing its jus the coil overs.....
Old May 13, 2010 | 08:20 AM
bounce your car a couple of times. if you hear the bump stops hitting together. Replace the shocks.
Old May 13, 2010 | 08:54 AM
ft541's Avatar
jus did this i hear nothing!!!
silverekjdm
27
Dec 10, 2008 05:20 AM
silversleeper
Feb 28, 2007 12:23 PM
baggedmazda
Jul 4, 2006 10:17 PM
crxh22project
Apr 24, 2005 01:43 PM
Zeke28
Nov 23, 2004 09:27 PM
