New numbers! AR Performance D16 520whp@18psi
520 whp @ 18psi
Nothing changed from last setup just a new stock sleeve block with fresh rings and bearings. Didn't get any video footage. Sorry
d16z6 block
-stock sleeves
-pistons and rods
-oem bearings
d16z6 head
-stock ports
-valve springs and retainers
-AR custom camshaft
-y8 intake manifold
- S2K TB
- 1000cc inj
- etc..
turbo setup
-SP6262(journal bearing)
-CC Ramhorn manifold
-38 wg
-tial BOV
-etc.
Hondata S300
More info to come
d16z6 block
-stock sleeves
-pistons and rods
-oem bearings
d16z6 head
-stock ports
-AR custom camshaft
-y8 intake manifold
- S2K TB
- 1000cc inj
- etc..
turbo setup
-38 wg
-tial BOV
-etc.
Hondata S300
More info to come
1+1=3
More details and a chart is needed for this to add up properly.
Previous thread for Reference: https://honda-tech.com/forums/forced-induction-16/ar-performance-d16-turbo-420whp-289wtq-%4014psi-2730068/
This video was of the last engine y8 block and z6 head. We have went through the whole disbelief of this engine making the power it is making on the amount of boost plus the simplicity of the setup already. I feel that the engine is just in a sweet spot for the combination of parts being used. I also feel that as the boost goes up the head will start to show it's low efficiency / cfm and not make as much hp per psi.
http://www.youtube.com/watch?v=nDVSKH1vd98
Only thing changed was the block, took out the y8 block and went with a z6 block. z6 head was refreshed with a valve job and that was it. I'll try to get copies of dyno graph. Did not go for more power because we did not need any more. This car has ran 10.7@ 135+mph on 475-480whp. We did some transmission work with higher gear ratios so we want to get the car hooking up before running more power. On top of that this is a stock sleeve block so we're close to the uncharted power levels for a stock sleeve d-series block.
Much love for the D-series, but 520whp on 18psi is low boost for that whp.
I know how it feels to have people discount your #'s, so I don't want this to come off the wrong way, but I made ~570whp on a dynopak on 17lbs on an F22c.
Hard to believe your motor is as efficient.
the best way to tell is if he ships off that cam to someone else with a D-series, and use the same turbo, also with E85,
and see if the same or close numbers can be achieved.
Theres gotta be something there thats doing it, wether it be crazy timing on E85, or that cam + turbo combo.
Yea these are pretty incredible numbers from such a mild d16 w/ stock head ports y8 manifold etc and that turbo at that amount of boost... even on E85 with a good tune.
In for more information.
Btw was this corrected or uncorrected numbers, what was the correction factor, etc? Was this on a dynopack?
Sorry to sound skeptical but its well beyond what most people have seen with a relatively similar setup.
The only thing different from your car and any other D-series is your cams, which you are magically trying to sell.
Either the design is amazing and you deserve all the future business you are going to get
OR
1+1=3
OR
1+1=3
also keep in mind guys this is done on 10:1 compression ratio. you have to read the original post.
btw 1+1=2
