walbro fuel pump
Old May 12, 2010 | 06:56 PM
bradennicely's Avatar
Icon2 walbro fuel pump
i just got a crx with a jdmb18b
it has a walbro 225 fuel pump is this necessary? seems to be drinkning down fuel
Old May 12, 2010 | 07:20 PM
D16SiHatch's Avatar
Default Re: walbro fuel pump
it's not necessary, but it won't cause bad gas mileage. something else is at fault for that
Old May 13, 2010 | 08:06 AM
djstevehawken's Avatar
stock injectors?
I put a walbro in my hatch with a udsm b18b (stock injectors) and notice no difference in gas mileage.
Old May 13, 2010 | 08:25 AM
yeah its stock injectors as well, is this fuel pump louder? slight humming sound?
Old May 13, 2010 | 08:33 AM
4g4dcruisin's Avatar
high flow pumps are used mostly for turbo setups. do you smell gas when your driving or what?
Old May 13, 2010 | 08:41 AM
no i dont smell gas at all, just sucks it down it seems like
also noticed there is 0 vacume lines ran could this be a problem? i know theres some you need but all of them? i cant seem to find a diagram for this
Old May 13, 2010 | 09:01 AM
yeah, the pump is louder than stock when it primes for me but this is normal. I can't notice any difference in noise when driving.
Old May 13, 2010 | 09:11 AM
Vac lines where? For the fuel rail/fpr?
Old May 13, 2010 | 09:37 AM
just the smaller vaccuum lines none at all ill try to get a pic on here
Old May 13, 2010 | 09:42 AM
Hmm, if you have no vac lines, then your fuel pressure regulator isnt working.
Old May 13, 2010 | 11:53 AM
<a href="http://s1033.photobucket.com/albums/a418/bnicely88/?action=view&current=bay.jpg" target="_blank"><img src="http://i1033.photobucket.com/albums/a418/bnicely88/bay.jpg" border="0" alt="Photobucket"></a>
hopefully this works and will help
sorry i only had my phone on me
Old May 13, 2010 | 11:54 AM
What vac lines did you say are missing? Because everything fuel related is there.
Old May 13, 2010 | 12:03 PM
usually you see line running here in most swaps
(mpfi swap is ghetto) this is the way i recieved the car needs work still haha
Old May 13, 2010 | 12:12 PM
MAP sensor is there, it looks like you have an obd1 throttle body, so the MAP sensor is located ON the throttle body.
Every other vac line is NOT needed. the purge solenoid is not needed, neither is the charcoal canister line.
Old May 13, 2010 | 12:16 PM
ok the only one i knew i didnt need it the throttle body line..
if its obd1 how come i have the (amp looking) resistor box still?
do you have to jump a wire to see what check codes your throwing when this swap is done?
Old May 13, 2010 | 12:17 PM
The the intake manifold could be obd1, and the fuel injectors could be obd0.
What ECU are you using?
Old May 13, 2010 | 12:18 PM
aalright that makes since. this is one of the most ghetto swapped cars ive seen the price was well worth it though thanks for the advice
Old May 13, 2010 | 12:20 PM
Get the fuel injector wiring shield (plastic piece that holds the wires and bolts to the fuel rail) and tape up then rest of the wires.
By the way, our cars look similar, based on your avatar.
Old May 13, 2010 | 12:31 PM
this weekend its all getting fixed/full tucked/ and gold bay as long as the weather stays nice
yeah i used to have a 91 lx it was auto though ,it was my dd for awhile full tuck/semi shaved bay its was pretty dope for an auto 1.5
Old May 13, 2010 | 12:52 PM
StayKrafty's Avatar
Braden, we're going to ky tomorrow
Old May 13, 2010 | 04:23 PM
D16SiHatch's Avatar
not normally into the mismatched engine bay theme, but for some reason on yours i dig it lol. i'm liking the wire tuck as well
bazoOKA_ TOoth
12
Sep 30, 2010 02:45 PM
MichealSenior
Mar 18, 2010 03:40 PM
camo_crx
31
May 10, 2006 08:16 AM
trooper0641
24
Dec 12, 2004 10:09 PM
Malgerus
17
Jun 14, 2003 08:08 PM
