People running Pro Web Cams
So, I'm trying out a new set of cams from Web. It's the .530/.510 setup w/ their rockers and I'm on the Ferrea hardware. I know there are at least 3 others that have this same setup.
My questions are.... what is everyone else seeing for degrees of seperation? What are people finding they end up at for cam gear settings when degreeing the motor? Where do they end up when you tune them (I know it differes from setup to setup)?
I'm just looking to make sure I'm in the right ball park.
Thanks,
Chris
Thanks,
Chris
What does the cam card say? Does it give you intake and exhaust opening and closing numbers? LSA? Lobe centers? ect
Use one to verify the other, when its right they will all match from web, their cam cards from what I have done have been dead on, compared to some other companies.
I've got the same kit and "tools" as the next guy. That doesn't answer my question though.
Moi, are you even using their Pro series camshafts? From the pic it sure doesn't look lik eit....
Actually, yes. I am positive wise ***.... Do you ever say anything positive or are you always a douche?
I have the head off the motor. I want to know ahead of time before I slap this thing all together, hence my questions. I didn't think it was too much to ask....
I believe is is simply asking what people have found to be good centerlines of the cams.
Web is Very Good at being on the money with what they recommend as the centerline.
As Tony said they should have include a cam card that will tell you where you need the centerline of the cams.
Good Luck
Good Luck
That is what I am asking for regamaster
No cam card was provided, but I know there is an online card available.
Maybe I should have been more clear.... I was looking for degrees of separation when checking V2V clearances.
The V2V measurement, and lobe separation go/no go minimum angle should be done on your specific head, since valve size, valve job, and number of valve jobs can effect V2V clearance. Not really a question that can be answered by other people setups or trusted from other people numbers for that matter.
