Wowww, really, ball joint?
I have a 95 GSR and am removing the axels. I have run into a problem though, i cant seperate the ball joints, this is my first time doing it alone. Help please! It would also help to have opinions on how to remove axels. Sry if repeated post!
With shock/spring and shock fork still bolted in place:
- remove castle nut
- jack up suspension
- place 1/2" ratchet handle behind knuckle, between knuckle and LCA
- release jack, ball joint stud will pop loose with a loud *bang*
Takes only a few seconds and works every time.
- remove castle nut
this video is what he is describing: http://www.youtube.com/watch?v=ISY8bGof3bQ
Yeah that's the video, I was too lazy to find it
this is the most unobtrusive, painless method of separating this ball joint. No hitting things with hammers, no ripping boots with pickle forks or anything like that, and it's much faster and easier than even the "proper" Honda procedure.
Using the "proper" tool on the LBJ takes 20 times as long as this method and you risk damaging parts, whereas this method has zero risk of parts damage.
rasinhell
Feb 3, 2005 01:47 PM
gojo0401
May 19, 2004 07:08 AM
