92 integra problem help!!!!!!
Old May 11, 2010 | 05:04 PM
repingjdm's Avatar
Icon2 92 integra problem help!!!!!!
hi so here my problem i got dis 92 acura integra dat wont go above 3.5 rpm for some reason was fine b4 so now when i drive and it hits 3500 rpm it won’t go past it and when it does hit3500 rpm the car slows dwn and idk what is making it do this now so if you guys could help me out with this problem dat would b kool thix
Old May 11, 2010 | 06:08 PM
MD426's Avatar
Default Re: 92 integra problem help!!!!!!
Jumped timing? Bad distributor, ECU programing messed up?
Try resetting your ECU, pull the 7.5amp fuse under the hood, it's labeled Back Up
Check to see if your timing is right, if that doesn't work then try to swap out the distributor.
Old May 11, 2010 | 08:25 PM
DA6 STYLE's Avatar
distributor.....I had the same prob before
Old May 11, 2010 | 08:30 PM
repingjdm's Avatar
ok i will check the timing 2marrow moring and see if thats not it will reset my ecu wll post if it wrks thix so far
Old May 12, 2010 | 03:26 PM
repingjdm's Avatar
ok so i checked the timing and it is ok my dad says it my fuel injector that are dirty or i need new ones what do u guyz think?
Old May 12, 2010 | 04:35 PM
MD426's Avatar
I don't think that would be the main problem, If your injectors were dirty then it would run really lean when getting into the higher rpm's if that was the problem causing not to go any higher and probably throw a code. Is it's throwing any codes? Happen to have a friend that would let you swap the distributor just to see if thats the problem.
Old May 12, 2010 | 07:50 PM
repingjdm's Avatar
havnt rlly checked if its throwing codes
Old May 12, 2010 | 08:17 PM
MD426's Avatar
The CEL would be on.
Old May 12, 2010 | 08:28 PM
repingjdm's Avatar
ok so just ran it dwn the road and my rpms went lowe i hav 2 shif at 3000 rpm now and i dnt rlly wnt 2 waste my money on a new Distributor if thats not the problem
Old May 12, 2010 | 09:07 PM
91_LS's Avatar
Anyone ever think his car might just be in limp mode?? And OP, have you ever changed out the fuel filter? Id also chick to see if "just maybe" the garment rings on the valve cover are leaking and oil is is grounding out the plugs?
Old May 12, 2010 | 09:12 PM
repingjdm's Avatar
just ran it again a sec ago and it ran just fine so idk
Old May 12, 2010 | 09:14 PM
repingjdm's Avatar
i took a vid of it while driving it 2 see if it would do it again and it ran fine so idk will post a link 2 my vid
Old May 12, 2010 | 09:15 PM
91_LS's Avatar
Pull the plug wires "one by one" so you don't mess up the order and look down the hole to see if there's oil on top of your plugs. And also, when was the last time you did a (FULL) tune up?
Old May 12, 2010 | 09:17 PM
repingjdm's Avatar
there fine just got the car about a week ago
Old May 12, 2010 | 09:19 PM
91_LS's Avatar
And also, when was the last time you did a (FULL) tuneup
And this?????
Old May 12, 2010 | 09:21 PM
repingjdm's Avatar
hav done one yet on it going 2 do it 2marrow when i get and do a tune up
Old May 12, 2010 | 09:25 PM
91_LS's Avatar
Ok. Whatever yo do,"DO NOT" get the cheep "auto lights" do it right and get NGKs. Change everything,plugs,wires,rotor and cap.
Old May 12, 2010 | 09:27 PM
repingjdm's Avatar
hahaha i know i dnt do any cheap parts on my car i got ngk right now i hate having cheap parts on my car
Old May 12, 2010 | 09:29 PM
91_LS's Avatar
lol good. I hate when people post up how there car is running like crap just to fined out there running cheep s**t..lol GL and let us know the outcome.
Old May 12, 2010 | 09:36 PM
repingjdm's Avatar
heres da vid my little bro took of it runing was wanting 2 get it on vid show u but it was bck 2 normal heres my car its a work in progress http://vids.myspace.com/index.cfm?fu...eoid=104906318
Old May 12, 2010 | 09:38 PM
91_LS's Avatar
Why you driving with the door open????lol
Old May 12, 2010 | 09:43 PM
repingjdm's Avatar
lol its not open the door light stays on when u turn it on lol got 2 fix it lol
Old May 12, 2010 | 09:48 PM
91_LS's Avatar
Just clean off the door switch. All it is is a ground switch. But anyways,hope Ive helped you out and you get her fixed. I'm off to bed. I got to keep one eye closed just so i don't see double..lol Damd med. Good night.
Old May 12, 2010 | 10:52 PM
MD426's Avatar
Old May 13, 2010 | 10:15 AM
repingjdm's Avatar
ok so i got a question if i reset my ecu is there going 2 be side effects if i do reset it going 2 do a tune up on it a bit to see if this fixes it
