Can I run LS Eagle rods in GSR ?
Old May 11, 2010 | 04:37 PM
99gsvtec's Avatar
Default Can I run LS Eagle rods in GSR ?
Have a guy that has brand new eagle rods part # crs5394a3d & is going to give me these along with cp pistons 81.5mm, acl bearings, Arp main & head studs, act race clutch & flywheel, plus cash for my 97 gsx dsm & not sure if these will work ive heard bearing width is off between LS vs GSR as well as the legth any help much appreciated
Old May 11, 2010 | 04:47 PM
jdm_sir2's Avatar
Default Re: Can I run LS Eagle rods in GSR ?
you can run the LS rods but ur gonna need to use an LS or B20 crank due to the difference in length and also bearing for an LS...running that setup it more of a true LS/Vtec u gain on the stroke GSR is 87.2mm vs LS 89mm mean more torque!
Old May 11, 2010 | 10:24 PM
C_Rock77's Avatar
You need an LS crank or GSR length rods. You might be able to find someone to trade you.
But to answer your question: You're correct, LS the rods & GSR/ITR crankshaft are not compatible.
You can, however, put LS crank & rods in a GSR block.
Short answer: You're going to need a different crank or different rods
Old May 14, 2010 | 11:29 PM
Toneco's Avatar
Originally Posted by jdm_sir2
running that setup its more of a true LS/Vtec u gain on the stroke GSR is 87.2mm vs LS 89mm mean more torque!
mybad for thread jackin.
is that reliable?
NathanMorris
Nov 30, 2004 10:01 AM
svmnredracr
Sep 28, 2004 07:46 AM
yimmy
Dec 30, 2003 07:26 PM
spettinger
Feb 12, 2003 03:10 PM
B18C-EJ1
Jan 19, 2002 11:45 PM
