Hondata!!!!
Old Sep 11, 2002 | 07:12 PM
I Like Boost's Avatar
Default Hondata!!!!
Its great and all but.... how the hell do i hook up the shift light.
i got it programmed in at 8k and right now only the check engine light flashes.
btw 97 gsr obd2 to obd1 harness p28 ecu if it matters.
help me out!
Old Sep 11, 2002 | 09:00 PM
Jesse H's Avatar
Default Re: Hondata!!!! (BEe18SeAONe)
their website has instructions.
Old Sep 11, 2002 | 09:36 PM
SIK IN DA HED's Avatar
New User
Default Re: Hondata!!!! (Jesse H)
yup.. peep out the instructions or ask the guys in the forced induction forum. they are hondata gurus.
if all else fails... ask DUSTIN.
[Modified by dlplayboy, 10:36 PM 9/11/2002]
Old Sep 12, 2002 | 09:34 AM
thegrinch's Avatar
do you have it so you can adjust the settings? What stage do you have? If you do have it you need to push the button that identifies with the shift light and then press the brakeow do the same for the 100's rpm. after you have done that the check engine light will blink twice and turn off. you are set to go.
Old Sep 12, 2002 | 10:00 AM
RedTeg95's Avatar
Default Re: Hondata!!!! (thegrinch)
If you have stage 2 or grater there is a connector on the blue box in which you can hook up an LED (which comes with the kit). The LED is on a long wire with a plug on the end to connect into the box. The length of wire is long enough you can put it in your guage cluster or anywhere else. I never bothered to hook mine up, I just use the check engine light.
5lugSlug
Engine Management and Tuning
May 4, 2008 04:58 PM
mauibuiltEK
Oct 26, 2006 09:45 PM
Paluce
Oct 11, 2005 05:52 AM
martini
Apr 22, 2003 11:27 PM
