Its great and all but.... how the hell do i hook up the shift light.
i got it programmed in at 8k and right now only the check engine light flashes.
btw 97 gsr obd2 to obd1 harness p28 ecu if it matters.
help me out!
help me out!
New User
yup.. peep out the instructions or ask the guys in the forced induction forum. they are hondata gurus.
if all else fails... ask DUSTIN.
[Modified by dlplayboy, 10:36 PM 9/11/2002]
do you have it so you can adjust the settings? What stage do you have? If you do have it you need to push the button that identifies with the shift light and then press the brakeow do the same for the 100's rpm. after you have done that the check engine light will blink twice and turn off. you are set to go.
If you have stage 2 or grater there is a connector on the blue box in which you can hook up an LED (which comes with the kit). The LED is on a long wire with a plug on the end to connect into the box. The length of wire is long enough you can put it in your guage cluster or anywhere else. I never bothered to hook mine up, I just use the check engine light.
