Y8 swap help
Old May 10, 2010 | 06:41 PM
ef90honda's Avatar
Default Y8 swap help
Ok i just did a dpfi to mpfi to y8 swap.I got a cel code 10.I know its the map sensor but every vacumm is hooked up.Its runs fine but i need it off to pass inspection.any help would be great thanks
Old May 10, 2010 | 06:47 PM
ExtraBlackRex's Avatar
Default Re: Y8 swap help
Call me crazy but doesn't a D16y8 come Multi Point already?
Old May 10, 2010 | 07:21 PM
D16SiHatch's Avatar
what don't you get? he converted his car to mpfi and then installed a y8 head..
op: code 10 is not for the map sensor, its for the idle air temp sensor. code 3 is for the map.
Old May 10, 2010 | 08:38 PM
Ok read it wrong, my bad.
Old May 10, 2010 | 08:48 PM
ef90honda's Avatar
well no i put the full y8 swap in it.But what could i have done wrong to make it throw that code?What to do to fix it.
Old May 11, 2010 | 05:57 AM
jlicrx's Avatar
my guess would be that you don't have the Intake Air Temperature sensor connected - the D16Y8 has the IAT in the intake tube before the throttle body, not in the intake manifold like most of the other D-series engines - did you install a sensor for the IAT and connect it?
the IAT sensor connector on your DPFI engine harness is a white 2-wire connector with red with yellow stripe and green with white stripe wires
this is one way to install the IAT in the intake tube:
Old May 11, 2010 | 05:11 PM
ef90honda's Avatar
well my car is running a obd0 pm6.but ill try that out an see what happens
Old May 11, 2010 | 06:40 PM
D16SiHatch's Avatar
so you're running vtec off of what then.. an rpm switch?
jlicrx: kind of interesting how that iat is fastened to the tube there lol
Old May 11, 2010 | 09:03 PM
ef90honda's Avatar
Not running vtec yet.I would run a swtich but dont really know how to wire that up
ARCHway Jtuned
Apr 22, 2007 09:10 PM
Wazup
Oct 26, 2006 06:25 AM
iNetForce
May 26, 2004 08:15 PM
DsMWookie
Sep 5, 2003 02:20 PM
Kusai.Nihonjin.Desu
Aug 18, 2003 02:25 PM
