blown head gasket.
Old May 10, 2010 | 03:24 PM
stevej1's Avatar
Default blown head gasket.
Just figured out my head gasket is blown. Should I even bother replacing it? I have a d16z6 with 153k on it. Should I just drop in a newer single cam? I want gsr swap but im low on cash. Advice?
Old May 10, 2010 | 03:41 PM
boosted84.5's Avatar
Default Re: blown head gasket.
I'd replace the head gasket. It's cheap, not that hard, and then you can save more cash for that gsr swap.
Old May 10, 2010 | 03:50 PM
jdmh22eg2's Avatar
+1 for relacing HG did motor over heat at all if so might want to check the head for being warped
Old May 10, 2010 | 11:23 PM
stevej1's Avatar
Yeah it overheats but only when i'm at idle. At first I was sure the gasket was blown but it wasnt throwing smoke at all but coolant was disappearing so I knew something was up. my oil looked fine too so I replaced a few things thinking and hoping it wasn't the head gasket but after nothing worked I was positive. fml.
Old May 11, 2010 | 12:08 AM
stevej1's Avatar
anyone know where I can find a hg kit for cheap?
Old May 11, 2010 | 06:47 AM
apexi_rsx's Avatar
overheats at idle? maybe your radiator fan is not kicking on or the switch is bad?
Old May 11, 2010 | 06:53 AM
nothing_shocking's Avatar
If it only overheats at idle, that doesn't sound like the HG... As far as the disappearing coolant goes, look for leaks before tearing the head off. Like apexi said, check the fan.
Old May 11, 2010 | 10:22 AM
Red_Army's Avatar
i just had to check all mine since i was losing coolant but no smoke no power loss no foam.
i had just gotten a new rad/fan. and turns out id just spit out a tiny bit out of the top hose. found that i just didn't tighten down the band camp as tight as it should be. no loss since.
Old May 11, 2010 | 11:50 AM
2ndthtsurplace's Avatar
if the cooland is goin somewhere and it isnt on the ground then just do an oil change i mean u need to drain the oil and clean the pan anyway if the head is blown but if u drain the oil and like 2qts of water/antifreeze come out then kno where the coolant went and u kno the headgasket is bad
Old May 11, 2010 | 12:29 PM
stevej1's Avatar
I replaced the switch and the radiator and the rad cap and thermostat and did a coolant flush. even ran a switch through the car so i could flip it on and off when i wanted. the car does throw a little smoke but it isnt white. so im pretty sure the hg is muffed up
Old May 11, 2010 | 12:39 PM
Noel L Eguia's Avatar
Replace the gasket. Don't let yo shell go.
Old May 11, 2010 | 12:49 PM
jdmh22eg2's Avatar
35$ 3 layer flepro HG at advanced auto parts, autozone FTW on a budget
Old May 11, 2010 | 10:33 PM
stevej1's Avatar
Do I need to whole gasket set? or just the hg?
Old May 11, 2010 | 11:16 PM
Wdpfreak145's Avatar
It would not hurt to replace some other gaskets while you're at it...
efjones9
May 1, 2009 06:48 PM
G0TB00ST
Oct 13, 2008 04:53 PM
windgatgp
Aug 20, 2007 12:33 PM
Frost_1097
Jun 18, 2007 07:21 PM
sleepyIntegra
May 24, 2004 11:14 AM
