B16 Valve Cover Stud size?
One of the four corner valve cover studs has stripped on the cam journal, so I am looking to put a Heli-Coil insert in to remedy the problem.
I need to know the size/pitch for the stud, where it connects to the cam journal so that I can get the correct Heli-Coil kit.
Stud Honda Part Number: 90012-PM7-000
For reference, part #24 in this diagram:
And here's where the cam journal is stripped, and needs the Heli-Coil:
Thanks in advance!
Thanks in advance!
i wouldnt use helicoil in that area..helicoils tend to pull out if there is to much stress on them..look for a steel pound in insert in that size..most hardware stores have/can order them.
would suck for bolt to come out and throw off timing or something..just my oppinion tho
acake em1
Apr 30, 2009 08:21 PM
Ignitecivic
Dec 14, 2003 09:28 PM
