brake booster problem or master cylinder...
Old May 10, 2010 | 11:50 AM
mikej94civex's Avatar
Default brake booster problem or master cylinder...
car is a 94 civic ex, problem is when i press the brake pedal it works fine, but its rly hard to push, like i gotta apply alot of force
just to slow down...brakes are all new and bled...
Old May 10, 2010 | 12:05 PM
Former User's Avatar
Default Re: brake booster problem or master cylinder...
Sounds like a brake booster problem. Start by checking the vacuum line and check valve.
Old May 10, 2010 | 12:42 PM
Thanks man, i'll lyk the results later...quick question tho, the vaccuum line off the booster is the one in the illustration comin off
the check valve to the right of the pic correct?
Old May 10, 2010 | 12:50 PM
Yes. And the hose to the left goes to the intake manifold. Check both hoses.
Old May 10, 2010 | 01:17 PM
Thanks much bro!
Old May 11, 2010 | 08:39 PM
deuxxx's Avatar
yeah, Brake booster sounds right as well,
It is not holding the vaccume from the engine which is main part of power brake.
I saw some parts (used) for $20s
Jtkdirtbike
Sep 8, 2013 03:48 PM
kazaa187
May 26, 2013 01:51 PM
cxca64
Feb 17, 2012 08:24 AM
lsnidex
Suspension & Brakes
Jun 3, 2009 08:27 PM
CIVIC96DXcp
Apr 18, 2005 07:48 AM
