99-00 climate control wiring help!
i need to know which wire coming out of the climate control plugs is for the compressor switch. there are 2 plugs with around 10 wires in each.
there is a wire that should connect the compressor switch to ground when you hit the button that says AC on it. if i ground the wires for the compressor it comes on, but i need to know what wire will allow the switch control when it is grounded and when it is not.
if anyone knows or has a pinout for the climate control unit PLEASE help me out here!
cazper51
Nov 22, 2010 02:38 PM
