low idle when stopping
Old May 9, 2010 | 05:22 PM
lsvtechatchy's Avatar
Default low idle when stopping
alright i have an ls/vtec. it is a b18a block with a b16a head, sometimes when i stop at lights my rpms go to about 200 to 500 rpms but never stalls, car runs strong but what could be causing this to happen?
Old May 9, 2010 | 05:26 PM
EJeff8's Avatar
Default Re: low idle when stopping
Need a plug,cap,wire and rotor tune up or you have a vac leak. Maybe a dirty IACV? But it woud fluctuate higher if it was dirty, not lower.
Old May 9, 2010 | 05:35 PM
gotcha i will have to check those. i forgot to mention that the block is stock internals too. what is the best wires and cap to purchase?
Old May 9, 2010 | 05:37 PM
EJeff8's Avatar
OEM is probably the best, but when I go to the Zone, I ask for mid level wires, Platinum 2's or 4's and a gold standard distributer cap and rotor set. It makes me feel like it's going to keep well and last long.
Old May 9, 2010 | 05:42 PM
ha the zone? Autozone right? i will have to go get the stuff for it then. also maybe i should have mentioned this is the beginning, when i start the car when its 100% cold it high revs to about 2500 until its warm then it drops to about a grand.
Old May 9, 2010 | 05:45 PM
EJeff8's Avatar
Still all the same symptoms, maybe you do have a dirty IACV. Also, if your car is dropping off that low at warm temp maybe your fuel pump is starting to die? That may be worst case scenario though.
Old May 9, 2010 | 05:59 PM
alrighty then on my next day off i will pull the IACV off and clean it, get the new wires and plugs and see how that helps out. seems easy enough.
Old May 9, 2010 | 06:18 PM
EJeff8's Avatar
Yep, shoot it with electrical cleaner, take a swab to the filter grill and slap her back on. A plug tune up is straight forward. Just, for the love of God, don't mix up cylinder numbers to the dizzy. It won't end well and it'd be a very stupid move.
Old May 9, 2010 | 06:31 PM
lol duly noted, thanks brotha
DEPintheCurve
Jul 18, 2012 03:17 PM
bizmackus
Feb 16, 2007 06:34 PM
epoch707
Mar 17, 2006 03:11 PM
CircuitFG
May 13, 2005 06:05 PM
Thirty-Nine
May 4, 2005 06:56 PM
