B16 wont rev past 7,000?!?!?
Old May 8, 2010 | 02:22 PM
TheStone's Avatar
Default B16 wont rev past 7,000?!?!?
Hey everyone,
Map sensor went out the other day so I put a new one in. Now motor wont rev past 7k in gear. Its fine when in neutral but not in gear. It kind of feels like a rev limiter but not really. Feels more like its being suffocated. Any help would be great.
Old May 8, 2010 | 07:07 PM
hondamn1320's Avatar
Default Re: B16 wont rev past 7,000?!?!?
Did you calibrate the TPS?
Old May 8, 2010 | 09:06 PM
TheStone's Avatar
Sorry, I meant map sensor.
Old May 9, 2010 | 11:05 AM
gre8one7's Avatar
happen to have new injectors? Been in a few cars with huge injectors and was flooding the motor around 7k
Old May 9, 2010 | 11:02 PM
SpeedjunkieDB1's Avatar
The knock sensor will cause the problem. are you running a chip ecu? get a p28 with a chip and disable the knock sensor on the ecu or install a knock sensor or trick the ecu which ever works better for you, but if I were you I get a p28 ecu chip it and disable the knock sensor and you be reving 8100, well thats my opinion since a couple of friends used to have the same problem. Hey hondamn1320 you're on rgv4cycle.net too right? I always see you on the chatbox.
Old May 9, 2010 | 11:12 PM
JDMb18c1HATCH's Avatar
not sure if this is possible but do you think the rev limiter needs to be adjusted?
Old May 9, 2010 | 11:53 PM
DARKB20's Avatar
Originally Posted by TheStone
Hey everyone,
if u can post future updates that will be great......
Old May 10, 2010 | 10:30 AM
TheStone's Avatar
Going to try a few things. Will update this week. Thanks gentlemen.
Old May 10, 2010 | 10:53 AM
Yeah that's me, lol.
philcivicjordan
Oct 19, 2015 12:30 PM
DA9Sleeper
Apr 26, 2011 12:49 PM
95b16civic
Mar 18, 2010 07:02 PM
b16civicrida
Mar 2, 2006 02:36 PM
rioninja
Aug 1, 2001 12:46 PM
