Running a catch can breather on my LS/V can anyone help?
Old May 8, 2010 | 12:16 PM
HandMadeEgRHd's Avatar
Default Running a catch can breather on my LS/V can anyone help?
So i dont know if anyone has asked this before but oh well. I want to eliminate the ugly box and pv/c valve on the back of the block while planing on putting in the catch can w/breather so can i eliminate that and just run my two port's off the valve cover or should i plan on running one port off the whole in the block and two off the valve cover, oh yea im planning on tig welding a block off plate over that whole, any input would help?
Thanx (ps sorry for grahmer and miss spelled words just bad at it)
Old May 8, 2010 | 01:06 PM
hondamn1320's Avatar
Default Re: Running a catch can breather on my LS/V can anyone help?
You can use a freeze plug to plug off the hole from the box. This is the part # I got from my search: Autozone 555-104.1
I'm going to run two ports off the back of the block. If I need to, run a drain into a tapped freeze box in the original box's position.
Old May 8, 2010 | 04:57 PM
97CTR's Avatar
I actually started mocking mine up today. The nipple fittings that the hoses go to on the block (they are allen plugs stock) are a prelude part, I don't have the part number handy but will look if you want it. I sprung for a Z10 plug, but the freeze plugs work just fine.
Old May 8, 2010 | 06:21 PM
thanx for the bolth of the ideas thats awesome. 97ctr that engine bay looks clean what brake line did you use and what throttle cable is that i have to moddify my bracket for the rhd. bug my whole enhine bay is shaved and tucked but just needs paint.
Old May 8, 2010 | 06:29 PM
97CTR's Avatar
3/16 stainless steel lines. Though I wouldn't recommend stainless if you aren't too concerned with it as it is harder to flare properly. Lokar throttle cable.
unspankable
Nov 4, 2013 02:20 PM
kielcivic
Jun 11, 2009 02:57 PM
jdmdohcek98
13
Jan 1, 2009 07:55 PM
incubusboy87
Aug 13, 2007 09:02 PM
912
Feb 12, 2006 05:27 PM
