cranshaft pulley bolt unbelievably hard to get off.
Old May 8, 2010 | 11:40 AM
h-o-n-d-a's Avatar
Default cranshaft pulley bolt unbelievably hard to get off.
I had my cranshaft off before to do a timing belt. and i wanted to change out my crank pulley and its soo hard to get off now. i have the proper tool (crank pulley wrench)to do it but are there any ideas to make it come out easier? i soaked it in penetrating oil and am letting it sit for awhile. but i had a pipe attached to my half-inch wrench and i still cant get it too break free. any tips ideas?
Old May 8, 2010 | 11:43 AM
300whpej's Avatar
Default Re: cranshaft pulley bolt unbelievably hard to get off.
impact gun
Old May 8, 2010 | 11:58 AM
ejprimo's Avatar
leave the compressor on with enough psi when you use the impact gun on the crank bolt..
Old May 8, 2010 | 12:56 PM
chinochanginc's Avatar
put a few drops of oil in your impact gun before using it...
if not you might have to heat up the bolt with a torch or something..
Old May 8, 2010 | 01:06 PM
RICKSAUTOMOTIVE's Avatar
i use a mac impact gun/wrench (gun sounds cooler though LOL) its got 625 foot pounds of torque but it has issues 5% of the time. breaker bars and cheater bars work. use craftsman breaker bars because they snap like twigs too sometimes. a gym membership might help too LOL
Old May 8, 2010 | 08:04 PM
akap's Avatar
remember, right tighty..lefty loosey. lol
Old May 8, 2010 | 08:14 PM
98civdx's Avatar
Master Detailer
^^ haha, impact or supper long pipe and jump on it.
Old May 8, 2010 | 10:54 PM
boxeocampeon's Avatar
def impact gun just be careful cus a lot of times when using an impact gun it ****s up the bolts threads when you pull it out
Old May 8, 2010 | 11:25 PM
not sure what you mean by this, but i have never had this issue with the threads or the bolt heads on the crank bolt. i have broke heads off with it, and i have seen guys strip lug nuts or snap the wheel studs, but not the threads on the crank bolt. but still wondering what youre meaning by this...as in how this could have happened to you.....
Old May 8, 2010 | 11:40 PM
not talking about the crank bolt but bolts in general. my experience when i used an impact gun to pull the bolts out of the rear LCAs it crushed the threads on the bolts on both sides. maybe i did it wrong im just saying
Old May 9, 2010 | 11:20 PM
stevej1's Avatar
impact gun is the way to go but if you dont have that..what I did was put it in 5th and have my buddy hold the brake while I cranked the hell out of it with a breaker bar. it broke the bolt though. so be careful..hahah
Old May 10, 2010 | 04:23 AM
96hb's Avatar
I guess I was lucky when I did mine. All I used was like a 2ft long extension and a half inch breaker bar. I wedged a screwdriver into the starter gear to keep everything still and used the end of my jack handle as a cheater bar. It broke free after a few good stomps.
Old May 10, 2010 | 05:38 AM
96 EX's Avatar
I put some heat on it and used an impact gun. My compressor only went to 100PSI though so I must have been lucky.
MurtazaDSM
Mar 2, 2012 11:14 PM
LeonardDB
24
Sep 8, 2011 10:29 AM
judunty84
27
Apr 5, 2007 12:07 PM
prelude1897
Jul 11, 2006 03:11 PM
94CivicSi
Aug 23, 2002 01:25 PM
