2000 gsr with oil coming out of the exhaust??
like the title says there's an integra with oil coming out of the exhaust.
the compression is 240 across.
what could be the issue??? i have not done a leak down test, i don't know how.
does this happen when the valve seals go bad? how do valve seals go bad??
just wondering how can oil get through the exhaust.
the oil is burning white, not blue. so that means that it is not going through the combustion chamber. some how it is just going through the engine out the exhaust with out being burnt, leaving white smoke for blocks with no oil in the oil pan at the end of an hour drive.
do the valve guides leak??
1990CrxSi
Dec 17, 2001 05:15 AM
