h22 Balancer shaft drive gear wont move??
Old May 6, 2010 | 09:11 AM
soiii's Avatar
Default h22 Balancer shaft drive gear wont move??
So I am replacing my timing belt and when I took off the front cover I found a shredded balancer belt. My question: is the balancer belt drive gear supposed to move freely? I tried to align the shaft by hand but it wont budge.
Old May 6, 2010 | 01:09 PM
soiii's Avatar
Default Re: h22 Balancer shaft drive gear wont move??
Originally Posted by PirateMcFred
It's supposed to move freely by hand unless you still have the alignment pin in the side on the rear BS.
The pin is out. This thing is frozen in there. Could this have affected the crank or any other internal parts? What are my options? I was thinking of putting a 2x4 on the pulley and hammering it with a mallet to get it loose?
Old May 6, 2010 | 08:51 PM
soiii's Avatar
Anyone have some suggestions or best options?
Old May 8, 2010 | 06:59 AM
soiii's Avatar
If it's siezed then just forcing it to turn is not a likely solution as the bearing(s) are prolly screwed. The cheapest/easiest thing to do do is to just not use the BSs at all. Do not fix it, do not run them, just leave the belt off. You'll have a slight increase in the vibration eminating from the engine but no other reliability issues, short or long term.
Alternatively you can pull the engine and remove them and apply a Kaizenspeed blockoff kit or the $20 DIY one that can be found in the FAQ. OR you can totally pull the block apart and fix it right and replace the galled BS shaft and the bearings so that it's back to proper functioning order.
Got it.....I will just leave the belt off. Thanks for your help Mcfred!
ef9_lover
Jun 20, 2011 04:37 PM
mister2racer
Nov 29, 2010 11:11 AM
IAluder95
Apr 21, 2007 09:57 AM
Calvinator
Sep 18, 2004 05:09 PM
poison
Jul 21, 2003 07:43 AM
