95 Civic Ex B18b Swap...Running Hot
Old May 5, 2010 | 10:36 PM
SlaminSohCivic's Avatar
Icon3 95 Civic Ex B18b Swap...Running Hot
Well ive got a 95 civic ex with a b18b1 swap in it just droped in 2 days ago..And i have the Fan Wired to when the key is on its running...Ihave Fan Switch Hooked up...I Bled The whole system...And it still over heated?...It sounds a little out of time Could that be issue...After i over heated i took thermostat out and filled system up an bled again...Now it says it runs under normal...But you touch anywhere on the motor its fire hot...i kno how hot a car is spsosed to get but its crazy hot....The whole motor is stock execpt...JG Adjustable Camgears...Msd Blaster 2 Coil...High Flow Cat...2.5" Intake...Act 3900 Xtreme Pressure Plate...Quaife LSD...H22 340CC injectors....But its all stock its not detianation or nothin.....???????
So what can this problem be? Thanks Guys
Old May 6, 2010 | 08:22 AM
80 dolla crx hf's Avatar
Default Re: 95 Civic Ex B18b Swap...Running Hot
water pump, or there is a clog in the radiator or some where in the cooling system
greencivic_0789
Apr 28, 2010 08:20 AM
ruvy01em2
Honda Civic (2001 - 2005)
Nov 28, 2008 07:18 AM
trueloveracing
Jan 10, 2008 04:15 PM
rasta420
11
Nov 20, 2002 08:05 AM
biggtopscott
Aug 21, 2001 02:14 PM
