When signaling, steering wheel vibrates
Old May 5, 2010 | 08:52 PM
G2_Fella's Avatar
Default When signaling, steering wheel vibrates
What's the deal here? I've noticed everytime I signal or turned the headlights on, my steering wheel vibrates. I've searched and googled and nothing came up.
Old May 5, 2010 | 10:22 PM
kaduku_'s Avatar
Default Re: When signaling, steering wheel vibrates
hmm, i honestly cant think of anything thats electrical that would cause that to happen... wierd.
Old May 5, 2010 | 10:34 PM
raidacaipo's Avatar
Could be low idle like 500rpms or less. Why? grounding issues maybe.. Usually when you turn on the lights or roll down the power windows the idle tends to go down.
Solution: Try adjusting your idle either by flat head screw driver on the throttle body or adjust tps to specs..
If those fail then look for a grounding issue.
Other possible causes: Bad motor mounts
prelude2.2vtec
Aug 9, 2011 11:30 PM
raverx3m
Nov 24, 2010 04:11 PM
ftrms
Mar 31, 2010 07:18 PM
jacksonww
Oct 26, 2008 03:49 AM
Frost_1097
Jan 15, 2007 11:31 AM
