Car making rubbing noise after tranny install
I recently installed a new tranny in my car. For some reason it sounds like something is rubbing while driving on the road. When I take it out of gear while the car is still rolling the sound appears to almost disappear but as soon as I put it back in gear it comes back. No sounds when the car is not moving or when I start it. Only seems to come up when I'm driving. Any help on what might be causing it? Also rubbing noise seems to get faster as I accelerate. Any input or ideas on what I should look at would be very helpful Thank you
no slipping at all, tranny doesn't grind and shifts really smooth. Clutch is still the same clutch i had from my old tranny and flywheel and before I did the install it didnt make the rubbing noise. Another way I can describe the noise is it sounds like a supercharger.
I hear the noise when I downshift and slow down after downshifting. Sounds like bad brakes, but it's just the sound of my clutch. My friend's stealth does the same thing. I just assumed foreign clutches are loud. My cold air also jumps into that sound when it's pulling air on the downshift...
bump anybody have any idea of what it might be? Also it kinda feels like something is rubbing against my shifter also when im driving...was browsing on youtube and found this video which pretty much how the noise sounds like.
http://www.youtube.com/watch?v=JZzZMlOVdg0
transmission doesn't grind and shifts really smooth. Noise only comes up when driving not when parked and in idle. Not to sure what is causing this problem so any help or idea on what to look for would be helpful.
E-lude78
12
Mar 12, 2002 05:37 AM
