Mini-Me swap help!!!
Old May 5, 2010 | 12:53 PM
stevieturbos's Avatar
Default Mini-Me swap help!!!
IM currently putting a mini me swap in my ef hatch...im using a d16y8 head and have converted the car to obd1 already...what distributor will work on the y8 head..... the z6?
Old May 5, 2010 | 01:02 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: Mini-Me swap help!!!
For your specific setup, any 92-95 Civic D-series non-VTEC distributor OR 96-00 Civic D-series distributor with OBD1 plugs will work.
The Z6 distributor has a unique flange that only lines up with the Z6 head.
Old May 5, 2010 | 01:35 PM
EFRue57's Avatar
use the y8 distributor and either convert the distributor plug on the distributor to obd1 plugs or convert the distributor plugs on the engine harness to an obd2 plug.
Old May 5, 2010 | 07:11 PM
if i use the 92-95 non-vtec dizzy that will work? i thought from what i was told that that wouldnt work...and if i use the y8 dizzy and convert to obd1 plugs are the wires the same color to match them up to the obd1 plugs from obd2? or if i used the obd2 plugs on my engine harness would i wire them the same as the obd1 color for color? and if i convert either of the plugs from the dizzy or my harness to obd2 it will not affect my obd-1 conversion and will work?
thanks for your guys help i appreciate it alot....
Old May 5, 2010 | 07:15 PM
bump
Old May 6, 2010 | 01:53 PM
24TEN's Avatar
PHANTOM MENACE
Dude did you even read that? I responded right after your post. Even EFRue57 answered for you. Need wire colors for the dizzy pinout? Have you tried looking in the FAQ already?!
The ECU doesn't care which distributor you have as long as it is sending the signals it needs to run the engine (if that went over your head an OBD2 distributor will not affect your OBD1 conversion provided you wire it properly, the only real difference between an OBD1 and OBD2 distributor is that one has two plugs and the other has one plug, same wires).
Old May 6, 2010 | 03:36 PM
yes i read it and did u read mine? i understand the ecu dont care but from wat i understood the non vtec one wouldnt work...i dont wanna spend the money and it not work thats my problem...so which one do u think would be the best idea? the y8 one or the non vtec one for the eg
Old May 6, 2010 | 03:52 PM
D16SiHatch's Avatar
i would just convert the plugs on the y8 dizzy to work because the non-vtec dizzy will NOT work. not without modification
http://www.d-series.org/forums/gener...th-busted.html
Old May 6, 2010 | 04:07 PM
thanks you thats what i needed to no i wasnt sure the non v would work cause i was sure it didnt but wanted to make sure before spending money..thank you for your help...
so all i have to do is convert the plugs on the y8 dizzy to obd1 plugs will the wire match up on the y8 dizzy to the obd1 plug? like the colors are the same?
Old May 6, 2010 | 07:13 PM
D16SiHatch's Avatar
no they're pretty much all different unfortunately
http://ff-squad.com/tech/wiring/obd1-2dizzywiring.jpg
if you are converting an obd2a big plug dizzy, i made this chart to figure out where the wires go. not one of the conversion charts i found was 100% accurate. i used this to convert my engine harness to obd1 plugs, but you could use it to change the dizzy plugs to obd1, same difference.
melissashelton1
Dec 21, 2009 12:28 PM
civicb16eg
23
Aug 29, 2007 12:10 PM
Laosakademiks
Mar 17, 2007 09:46 PM
IDriveHonda
Jul 8, 2003 07:03 PM
b16 matt
Feb 10, 2003 06:46 PM
