del sol exhaust question
Old May 5, 2010 | 11:46 AM
CivicTT's Avatar
Default del sol exhaust question
the background:
I own a del Sol S with the D16y7. I am in the process of doing a B18c1 swap into the car.
with that being said....
Im looking on ebay for a catback as a temporary solution so i can get this swap in. Im noticing on some websites they are saying "will fit S and SI model, but not VTEC"
Does anyone know the difference as to why and if this is something i should be concerned with or are they just listed wrong? someone suggested that the manifold is a different length on the D series vs the B series so the B pipe is longer. can anyone confirm?
Old May 5, 2010 | 11:52 AM
Hill4589's Avatar
Default Re: del sol exhaust question
B series exhaust manifolds are longer I believe, buy an exhaust for a del sol VTEC.
Old May 5, 2010 | 11:56 AM
CivicTT's Avatar
thats the problem im running into, a 2.5" exhaust on ebay is rare enough..2.5" "vtec" exhausts are non existant without dropping more than $200 (the most i wanted to spend was $150)
Old May 5, 2010 | 12:08 PM
LambertdelSol's Avatar
I don't think you're going to find a DOHC VTEC exhaust for a del Sol under $200. If you do, you're lucky. But yeah, any exhaust that say DOHC VTEC will fit with the B18. I did the same a couple of years back. I swaped a B18C1 in my del Sol and the VTEC exhaust fit perfectly.
Old May 5, 2010 | 12:21 PM
CivicTT's Avatar
guess ill have to expand the budget a bit, thanks for the info
ShinotakuX
Dec 16, 2021 07:04 AM
Corksil
Dec 3, 2012 06:33 PM
BrianDelSol
Sep 30, 2004 03:49 PM
B16ADelSol
Jul 15, 2004 03:39 PM
S2KAP1
Aug 21, 2003 06:18 PM
