98 civic si(Canadian) 01 GSR swap
Old May 5, 2010 | 05:12 AM
mikess's Avatar
Default 98 civic si(Canadian) 01 GSR swap
p06 chipped ecu
throwing lots of codes...12,13,14,16,17,21,22,23,41,43,45,61..
Everything is wired properly and it idles at 2000rpm
limp mode of course
smells like gas
timing is right on
Can anyone figur this out thanks
PCV????
Old May 5, 2010 | 08:32 AM
mikess's Avatar
Default Re: 98 civic si(Canadian) 01 GSR swap
Anybody!!!!!!
Old May 5, 2010 | 10:12 PM
itslogz's Avatar
Are you positive the ECU is chipped and chipped for the gsr if so? That many codes, it seems like something isnt right, especially if you are positive everything is wired correctly.
Have you opened the ecu to make 100% sure its actually chipped, but even then you cant be certain what basemap/etc is on the chip. Unless you got it chipped yourself..
The main deal with the codes you list are for vtec solenoid and pressure switch, IACV, and O2 sensors and every fuel system code. If everything is wired correctly, im going to have to say something with the ECU is faulty, or its not chipped or something of that nature. Ive never heard of someone having all those codes at once lol
Old May 6, 2010 | 05:24 AM
mikess's Avatar
The guy that chipped the computer is well known in the area and has done one for me before.....but i was thinking the computer also. Gonna run some chaeks today and see what happens. Thanks for the input
HU MAN CHU
Oct 1, 2011 02:47 AM
JeffBro
Engine Management and Tuning
11
Jan 5, 2011 04:20 AM
elmejor
Aug 24, 2008 05:39 AM
ek4_b16a
Jan 18, 2007 07:21 AM
hybridmoose
Apr 24, 2003 03:50 PM
