Assistance please? weird problem with integra
Old May 4, 2010 | 05:22 PM
gravity73's Avatar
Default Assistance please? weird problem with integra
I searched and could not find anything on the exact problem that I am having.
Hopefully somebody can help me out.
My 94 Teg, stock b18b, the car was running great! I noticed my water pump leaking, so I replaced it, along with the timing belt etc. I set the timing SPOT ON! The car runs great til 2800-3300 rpm, that is where the car just bogs, will not accelerate until it passes the 3300 mark.
Could it be the timing? << I ask that question even though I KNOW I set it perfect, I also notice my gas mileage is only like 18mpg where before the work I was at around 28mpg.
HELP!
Old May 4, 2010 | 09:21 PM
honda_luvr_2000's Avatar
Default Re: Assistance please? weird problem with integra
Originally Posted by honda_luvr_2000
sounds like you didn't get the cam timing right when you put the new timing belt on. Did you use anything to lock the cams in place before you removed the old timing belt? I'd check the cam timing before you do anything else. The CR-V's are farely tricky to set. If we all had three hands they would be cake. In the top of both cams on the #1 cam caps there is a alignment/guide hole and a hole in the cams. Put two allens or screw drivers in there that are as close to the size of the holes as you have. That'll hold the cams in place close enough. Then when you going to put the belt on, take two 12mm wrenches, put one on each cam gear bolt and turn them (with allens/drivers still in alignment holes) slightly away from each other (intake clockwise, exhaust counter clockwise). Now hold both of those wrenches, while (with your third hand) put the timing belt on the cam gears (crank gear, tensioner, water pump, intake cam gear, exhasut cam gear) and set & lock down the tensioner. Now let go of the cam gears & remove the wrenches & allens/drivers. Rotate the engine 2 times (one full cam rotation) and double check your timing & tension. Should be good & slight slack in the belt between the cam gears is normal & ok, but too much will cause problems.
I quoted & pasted this because it very well could apply. I know it's about a CR-V but it's the same cylinder head, timing belt, water pump, crank & gear (and oil pump while I'm naming same parts under those covers). A few questions...
Did you lock the cams before removing the old timing belt?
Did you rotate the crank twice (cams one full rotation) and recheck timing after the new belt?
If the answer to both is yes then you may want to check the timing anyway. If all you did was t-belt & water pump, no other things (plugs, wires, cap, rotor), and you didn't unplug and forget to plug back in anything, then there's really nothing else other than cam timing to check first.
Old May 5, 2010 | 04:38 AM
gravity73's Avatar
The answer to both of your questions is yes. I can't count how many times I have done a timing belt on a honda. I will though take it apart this weekend and see whats up, was just hoping it was something else.
Thanks
Old May 5, 2010 | 06:20 AM
Scott_Tucker's Avatar
I would agree that it is probably retarded one tooth. Timing being retarded causes the effective compression ratio to be lower, thus causing the lack of power. Even though you've done it a bunch of times, you're still human and make mistakes.
Old May 6, 2010 | 03:35 PM
bryse68's Avatar
sounds like timing belt is off.
julianbc2
May 31, 2010 04:51 PM
slowpokesi
Feb 19, 2005 06:39 PM
90crxsib16
Jan 12, 2005 03:15 PM
intekragsr
Mar 21, 2003 10:23 AM
baonest1
Feb 24, 2003 03:37 PM
