What should i torque my arp headstuds to? 800hp build!
Old May 4, 2010 | 01:35 PM
1sicef9's Avatar
Default What should i torque my arp headstuds to? 800hp build!
Ok im ready to drop my head on my motor and the arp headstuds i ordered dont have any torque specs ,i know the oem specs but im not sure if i should go with them because the motor will be seeing 800whp when its done!
its a gsr motor by the ways .
so all you high hp guys what do you have yours torqued to?
Old May 4, 2010 | 01:42 PM
.adam.'s Avatar
Default Re: What should i torque my arp headstuds to? 800hp build!
go on arps site or search. make sure your using moly lube or else the torque spec is going to be different.
Old May 4, 2010 | 02:54 PM
attack666's Avatar
know someone with the same power, torques his Arp studs to 85.
but your better off searching in arps site.
Old May 4, 2010 | 05:30 PM
PaddingtonBear's Avatar
800hp car. does not know how to find torque specs. does not compute.
Old May 4, 2010 | 05:53 PM
boostinh2x's Avatar
^x2
Old May 5, 2010 | 05:41 PM
1sicef9's Avatar
man if your gonna be a ******** why post?
if your not going to help please dont post ...thanks
Old May 5, 2010 | 07:00 PM
beansandrice's Avatar
lol
Old May 6, 2010 | 06:31 AM
90Rexx's Avatar
the torque spec according to ARP is if i remember correctly " follow the manufacturers reccomended torque steps" then finish with 80 ft. lbs.
ARP studs are tested to withstand tens of thousands of pounds of lateral stress... your 800hp car isnt going to blow your head off the block because your ARP studs are only torqued to spec. when i do my ARP studs, i go 26 then 52 then 80
Old May 6, 2010 | 12:38 PM
1sicef9's Avatar
thanks alot !
Old May 6, 2010 | 03:17 PM
TEAM ASSASSIN SI's Avatar
i torque my arp's to 85ftlb in a 3 step order hope that helps
Old May 6, 2010 | 03:58 PM
EG1834's Avatar
As mentioned, look up your part number on ARP's website. Too easy.
PACT man
Sep 7, 2008 10:28 AM
crxkid24
Dec 1, 2006 10:02 AM
djtony5
Nov 17, 2005 02:48 PM
