JDM H22 swap into 98 civic coupe...HELP!!!
Old May 4, 2010 | 10:49 AM
H22_PWR's Avatar
Default JDM H22 swap into 98 civic coupe...HELP!!!
okay so i have a 98 civic coupe 5 speed, and i had a 97 usdm h22 swapped in, that motor blew and i bought a 95-96 jdm h22 to replace it and now the car wont start???there is no sensor on the oil pump side of the engine of the jdm engine and there is on the usdm engine...also using the distributor from my usdm engine...i get it to crank but no spark is going to the spark plugs???what is wrong and how do i fix it???thanks
Old May 4, 2010 | 11:15 AM
EJeff8's Avatar
Default Re: JDM H22 swap into 98 civic coupe...HELP!!!
What are the CEL codes? I'd be inclined to think the distributer is the problem, considering you just said it doesn't match with the engine.
Old May 4, 2010 | 11:16 AM
EJeff8's Avatar
Also, JDM and USDM aren't just plug and play. There will be electronical differences and mechanical differences to some aspects.
Old May 5, 2010 | 09:13 AM
H22_PWR's Avatar
bump....need help...
Old May 5, 2010 | 09:26 AM
92civlude's Avatar
The USDM dizzy has no crank sensor. Its on the front timing pulley on the 97 H22. The JDM H22 has the crank sensor built into the dizzy.
Old May 5, 2010 | 04:14 PM
H22_PWR's Avatar
exaclty so how do i get it to work now that i already bought the jdm engine and its sitting in my car???
Old May 5, 2010 | 04:39 PM
EJeff8's Avatar
...Get a JDM dizzy.
Old May 5, 2010 | 09:19 PM
H22_PWR's Avatar
so will the jdm dizzy have the crank sensor on it so i can just plug it up???and then it will start just as long as that is the problem???where can i get one from???
Old May 6, 2010 | 09:09 AM
EJeff8's Avatar
Yes, the JDM will be fully assembled with sensor. And Distributor King
HandoEX
May 3, 2006 03:12 PM
Bigjussin
Jul 23, 2005 01:00 PM
BoOstInHaRd
Mar 26, 2005 12:44 PM
Race Egr
Sep 22, 2003 12:57 PM
