Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
02 sensor replacement, now dtc p1157
Old May 3, 2010 | 10:09 AM
adorek24's Avatar
Default 02 sensor replacement, now dtc p1157
I replaced both o2 sensors in my 04 Accord 5-manual I-4 with 69000 mi over the weekend because I was getting the dtc p0420, catalyst system below threshold. Good news: that dtc went away. Bad news: the engine light went back on and I pulled a p1157 dtc. This code relates to the primary (upstream) sensor and indicates high voltage in that sensor. Both sensors were Denso OEM, # 234-9040 for the upstream and #234-4797 for the post catalytic sensor. I've reset the MIL using my scan tool and by disconnecting the battery, but in both cases it came back on.
My guess is the pcm is not reading the new sensor within it's parameters. Is the dealership my only option here since they can reflash the computer and have the advanced diagnostics? They are charging $109 just for the diagnostic, so I'd rather not. I've already failed MA emissions and need to get this taken care of. Thanks in advance.
Old May 10, 2010 | 04:30 PM
adorek24's Avatar
Default Re: 02 sensor replacement, now dtc p1157
turns out my friend didn't secure the electrical connection on the primary sensor and so i snapped it in myself and now the car is fine, check engine light off. glad i decided to double check it before heading to the dealer.
Silver17
Honda CR-V & Element
Dec 31, 2019 02:53 PM
Dennin01
Acura TL, RL & ZDX
Sep 23, 2018 07:17 AM
xcxeon
Jan 24, 2018 04:05 PM
WSBowles
Apr 12, 2017 04:11 PM
craigmack14
Nov 2, 2009 05:08 PM
