vibration during acceleration
Old May 3, 2010 | 07:56 AM
AllmotorGSReg's Avatar
Default vibration during acceleration
ive been having this vibration issue lately, i needed new cv shafts so i replaced both cv's with new advance auto cv's (new, not remans) the car also has good ball joints new outter tie rod ends. The vibration occurs when the car is under a load, when i am going uphill or in 4th gear when im in low rpm's and give it gas. Just trying to get a few more opinions on this thanks. it doesnt seem to be vibrating under normal driving conditions.
Old May 3, 2010 | 08:09 AM
Default Re: vibration during acceleration
also my suspension is getting pretty old (one rear strut is blown) so maybe the bad suspension could be the culprit? My shock absorber bushings in the lca's are also iffy...
Old May 3, 2010 | 08:33 AM
GSR936's Avatar
check your mounts? wheels balance?
Old May 3, 2010 | 08:39 AM
hondamark35's Avatar
mounts yes, wheel out of balance would relate directly to speed not engine load.
AllmotorGSReg: i'm having a similar problem on my '01 accord. i ruled out the mounts so now i'm investigating CV axles. it seems you've done the inverse, now you just need to check the mounts. check all five (three if you've swapped sans torque mounts). also check for any loose bolts or excessive free-play in the suspension, driveline and subframe... just to rule that out.
Old May 3, 2010 | 09:14 AM
my axles were shot, my passenger side actually broke and my driver side was about to thats why the axles were replaced asap, the vibration isnt as bad with the new axles but it is still there, mainly under/around 3k rpms under a load. Ive checked my mounts and the only mount that makes me suspicious is the rear mount that the t bracket bolts to, when i rev up my motor looking at the rear mount i can see the t bracket slightly rock back and forth the back side of it where it connects to the mount, all bolts are tight. I have innovative mounts but there pretty old as well, and have seen some 5k launches at the track with drag radials, so maybe its time for some new mounts
rattlecanjoe
Feb 16, 2007 12:48 PM
jerBEAR
Sep 27, 2006 05:14 AM
19dabeast85
Jun 15, 2006 05:43 PM
VTECcnIT
Mar 8, 2006 02:04 AM
teler86
Suspension & Brakes
May 8, 2005 10:53 AM
