oil seal replaced still leaks
i replaced my clutch and flywheel little did i know i had a broken axle cause m friend had my car when it happend. so i get it back together go to put in pass axle and its busted in the boot very shitty feeling a long pause and a trip to the nearest auto zone i had a **** time bleeding the clutch replaced master then a few days later i realized that i saw oil on the ground. it was all over that axle so i brake cleaned it up and sure enough the seal was leaking so i got a honda part for the 2000 civic si installed it no problem fit perfect and it was dry for a week now leaking again wher whould yall start. thanks in advance
No if you overfilled it then it would have overflowed from the top. I would replace the seal again and make sure your axle is pushed in all the way. Autozone axles are crap and could easily back itself out.
peekeesh
18
May 1, 2010 01:21 PM
