586whp LS-T
Old setup here
https://honda-tech.com/forums/forced-induction-16/got-torque-ls-turbo-dyno-2509135/
Changes from then include -
BEP S362ett .70ar
T1 shroud w/ spal fan
Injector Dynamics 1000's
Bosch 044 w/ T1 install kit
Omni 4bar map
Had to flip the comp side to the drivers side to get that big turbo to fit on the InlinePro mani. Gonna build some ghetto piping to come out my headlight for ram air at the track, lol. It helps. Sorry no dyno sheet, but I have the vid. I will post sheet when I pick it up. Big thanks to T1 for getting the bugs out and getting it to run right. Hope to run some times soon! Boost was around 35psi!!!
The Vid -
http://www.youtube.com/watch?v=bSSBkY2N1sQ
BEP S362ett .70ar
Omni 4bar map
The Vid -
Thanks guys, its revving to 8250rpm with crower springs and tainers and bc ls turbo cams. I will post graph when available. Ha Ha, I made the same power as you kte324. Any strip times?
Not trying to down whomever tuned the car. You could make quite a bit more power. When he hits the gas its way to rich during spool up. A leaner then stoich mixture will spool a turbo up faster then if the car is fat.
tune looks on point to me. Making it a lil leaner u wont see a big jump in power in the low end. BTW i think thats Tony1 tuning the car so i think he knows what he's doing
Nice numbers, although at the end of the day a simple head swap would be worth a ton of power, do what you do man
LooL
LooL
LOL. I'll work on that.
When you stab the throttle it pretty much instantly goes to a couple psi. So I should run it leaner than stoich at 2-3psi to make it spool quicker? What a/f ratio should I make it there? What do I do when it misfires from being too lean?
Thanks for the props guys!
great numbers man, and way to **** off the ones who cant handle the fact your acheiving what you are.
and questioning Tony as a tuner well shows how ignorant you really are 30psi_gst
You'll work on that! LOL! How many other cars have been to you to just 'tinker' with?
Let me send you a PM.
