586whp LS-T
Old May 2, 2010 | 05:16 PM
97hb's Avatar
Default 586whp LS-T
Old setup here
https://honda-tech.com/forums/forced-induction-16/got-torque-ls-turbo-dyno-2509135/
Changes from then include -
BEP S362ett .70ar
T1 shroud w/ spal fan
Injector Dynamics 1000's
Bosch 044 w/ T1 install kit
Omni 4bar map
Had to flip the comp side to the drivers side to get that big turbo to fit on the InlinePro mani. Gonna build some ghetto piping to come out my headlight for ram air at the track, lol. It helps. Sorry no dyno sheet, but I have the vid. I will post sheet when I pick it up. Big thanks to T1 for getting the bugs out and getting it to run right. Hope to run some times soon! Boost was around 35psi!!!
The Vid -
http://www.youtube.com/watch?v=bSSBkY2N1sQ
Old May 2, 2010 | 05:39 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: 586whp LS-T
graph? what are you revving to?
Old May 2, 2010 | 05:43 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
wow thats sick. props man.
Old May 2, 2010 | 06:02 PM
Natural Aspirations's Avatar
ZOMG noo it doesnt have a top mount a vtec head or flashy parts.
What it does have is well thought out parts used correctly!
Old May 2, 2010 | 06:08 PM
kte324's Avatar
good job, great turbo.
Old May 2, 2010 | 06:17 PM
97hb's Avatar
Thanks guys, its revving to 8250rpm with crower springs and tainers and bc ls turbo cams. I will post graph when available. Ha Ha, I made the same power as you kte324. Any strip times?
Old May 2, 2010 | 06:30 PM
victor.ek4's Avatar
Congrats.
Love simple setup's
Old May 2, 2010 | 07:00 PM
ShanghaiOC's Avatar
Simple setup, great numbers! What tranny are you using to put that power down? Oh yeah, looks like you need to edit your sig now...
Old May 2, 2010 | 10:33 PM
30psi_gst's Avatar
Not trying to down whomever tuned the car. You could make quite a bit more power. When he hits the gas its way to rich during spool up. A leaner then stoich mixture will spool a turbo up faster then if the car is fat.
Old May 3, 2010 | 04:02 AM
boosted k20's Avatar
tune looks on point to me. Making it a lil leaner u wont see a big jump in power in the low end. BTW i think thats Tony1 tuning the car so i think he knows what he's doing
Old May 3, 2010 | 06:15 AM
kte324's Avatar
No, not yet. I will have some very soon, when the dss 3.9 and slicks get in.
Old May 3, 2010 | 06:34 AM
ghostofnyc's Avatar
nice bump for inline pro making power :D
Old May 3, 2010 | 07:49 AM
96 GSR-T's Avatar
Nice numbers, although at the end of the day a simple head swap would be worth a ton of power, do what you do man
LooL
Old May 3, 2010 | 10:35 AM
ctr32's Avatar
what all u got done to the block? mann i got the same valve train crower springs and cams and my tuner only took it too about 7500
Old May 3, 2010 | 10:37 AM
96EJ6LX's Avatar
It's sad to see a civic on a trailer when it can only run what, 11's maybe 10's.
Old May 3, 2010 | 10:43 AM
tony1's Avatar
LOL. I'll work on that.
When you stab the throttle it pretty much instantly goes to a couple psi. So I should run it leaner than stoich at 2-3psi to make it spool quicker? What a/f ratio should I make it there? What do I do when it misfires from being too lean?
Old May 3, 2010 | 10:44 AM
th3pwn3r's Avatar
It's sad to see retards posting on Honda-tech
Old May 3, 2010 | 10:55 AM
96 GSR-T's Avatar
Grabbing the popcorn
Old May 3, 2010 | 11:38 AM
97hb's Avatar
Sorry, it wasn't running before the tune. Only way for me to get it to the shop was tow, lol. I did drive it home after the tune, no bucking like the pte 1k's, its smooth now.
I'm still on stock sleeves with no block guard. Just copper sprayed hg and arps to 80lbs and its holding fine so far. I think stock port head is my biggest restriction now.
Thanks for the props guys!
Old May 3, 2010 | 12:59 PM
raene's Avatar
Is it a 3" compressor outlet on your BEP cover?
Great #s btw
Old May 3, 2010 | 02:41 PM
sanman000719's Avatar
great numbers man, and way to **** off the ones who cant handle the fact your acheiving what you are.
and questioning Tony as a tuner well shows how ignorant you really are 30psi_gst
Old May 3, 2010 | 06:34 PM
ShanghaiOC's Avatar
You'll work on that! LOL! How many other cars have been to you to just 'tinker' with?
Old May 3, 2010 | 07:41 PM
30psi_gst's Avatar
Let me send you a PM.
Old May 4, 2010 | 06:01 AM
95B18BTurbo's Avatar
Damn those are some awesome numbers! I certainly am jealous! Good luck at the track with that monster and keep us posted!
Old May 4, 2010 | 09:15 AM
SpoolnG2's Avatar
The best way to do it...KISS
Nice setup and nice power dude. Good luck at the track.
