S300 chips looked like this when I open the ecu.
It keeps bogging out. Misfiring. I took out the stock ignition coil and installed my MSD in. Drove good for a while but today its starting to act up again. Do you think I might need to replace the Ignition module too?
Did you try disabling the S300 to verify the stock side?
If you're experiencing circuit component deterioration there's always a chance a few solder locations could be questionable. You might want to look over it again before you start replacing things, and do a pinout test for shats & giggles.
Last edited by VegasInvasion; May 25, 2010 at 02:01 PM. Reason: Happy birthday to the GROUND!
replaced the dizzy and 02 and spark plugs. still doing the same ****. it runs fine again when i unplug the ECU and let it sit for a while and then plug the ecu back in. wtf?
verify it running rich with a WB02 meter first before going out and buying needless parts and just shotgunning the problem. Use the S300 as the tool that it is and diagnose your problem then replace the parts you have.
How do the plugs look after a start? Are they wet or very black? Do you have any misfires? Are they severe or just faint pop every now and again? Start with those items.
Double check all you ignition connections that you have made for tightness and or corrosion. In S manager is your timing jumping all over the place, or is the cell tracer moving around to a couple boxes all the time or sitting still at idle?
You have alot you can look at before just buying parts that may not fix the problem.
Plugs look very black. I have a lot of misfires and bogging. Mostly faint. I just replaced the distributor. It ran good for like 3days then it started to do it again.
How do you hook up the WB02 to the s300 and have it calibrate and drive tune itself?
dc5campo
Engine Management and Tuning
Nov 7, 2010 05:15 PM
