1990 Honda Civic (4door) Dies when I press on gas hard. Please Help!!!
As from the title... I have a 1990 Honda Civic. It starts fine and idle's fine. If I ease into the gas pedal it will get up to speed but if I slam on the gas it dies.
I really would like to figure out what it causing this.
ECU blinks... 1, 7, 10, 16
It spits and sputters when I hit the gas and it doesn't want to accelerate
Yea dude check those codes & start with the simplest/cheapest things & go from there. i.e. check sensors to make sure they're good & replace that fuel filter
MAF? thought 88-91's just had a MAP sensor..I would say clogged fuel filter, friend of mine w a 87 prelude had the same problem, but try changing or testing the fuel pump
tghonda
Honda Civic (2006 - 2015)
Oct 19, 2012 06:31 PM
Tim Manhattan
Apr 21, 2012 08:48 PM
