CEL blinks, Speedo revs, car wont start
Old Apr 30, 2010 | 05:32 PM
FlewByU352's Avatar
Default CEL blinks, Speedo revs, car wont start
I know someone had this problem before but I cant remember what it was or what to even search to find out how they solved it.
Old Apr 30, 2010 | 06:20 PM
FlewByU352's Avatar
Default Re: CEL blinks, Speedo revs, car wont start
Trans-Chassis ground was off, turns over but I dont hear the fuel pump.
Old Apr 30, 2010 | 06:30 PM
Former User's Avatar
Thermostat housing ground loose, corroded, or disconnected?
Old Apr 30, 2010 | 06:44 PM
FlewByU352's Avatar
checked it when I connected the trans ground wire and it was on tight ad what not. Its a fuel issue now I dont think the pump is getting a signal. IDK what needs to be hooked up I even switched out relays
Old Apr 30, 2010 | 07:06 PM
Do you have spark? When you turn the key to ON(II), does the CEL sttay on or turn off after 2 seconds?
Old Apr 30, 2010 | 07:13 PM
FlewByU352's Avatar
it turns off, no CEL nows it will crank but its not getting fuel
Old Apr 30, 2010 | 07:38 PM
Spark at the plugs?
Old Apr 30, 2010 | 07:41 PM
FlewByU352's Avatar
yeah it has spark just no fuel pump
Old Apr 30, 2010 | 07:46 PM
Are you guessing or did you check because troubleshooting takes a different direction depending on whether there is spark or not.
What year Civic?
Monstrositybl
Mar 8, 2017 11:04 PM
opc
15
Dec 21, 2014 06:19 AM
lplaza
Honda Civic (2001 - 2005)
Jun 24, 2014 02:33 AM
UnLuckyy
Sep 2, 2010 04:29 PM
supermario680
Sep 26, 2008 04:14 PM
