replacing axle, do i need to change oil?
Old Apr 30, 2010 | 03:44 PM
peekeesh's Avatar
Icon2 replacing axle, do i need to change oil?
I'll be replacing my axle later and was wondering if I can reuse the transmission oil. the reason I asked is because my transmission has just been replaced on Monday.
any ideas? can I just recycle the oil? thanks!
Old Apr 30, 2010 | 04:02 PM
alphalanos's Avatar
Default Re: replacing axle, do i need to change oil?
If its fresh yes. But you might as well put new Honda ATF/MTF in it. wont hurt.
Old Apr 30, 2010 | 04:09 PM
BryanM.'s Avatar
Resident Gearhead
I would try to reuse the fluid. Empty the trans into a clean container.
Old Apr 30, 2010 | 04:12 PM
peekeesh's Avatar
ok i will reuse the oil. i guess i can replace it later on if the axle has no problems whatsoever. thanks for the advice
Old Apr 30, 2010 | 05:24 PM
Blahblah718293's Avatar
didnt say if its auto or manual, either way, theres shouldnt be much if any fluid leaking out. if it does leak it should only be a few drops.
i wonder why the transmission was replaced earlier this week and someone left a bad axle?
Old Apr 30, 2010 | 07:00 PM
98civdx's Avatar
Master Detailer
Agreed with above,
But, ^^ only a couple drips? when we pulled my friends da tranny it poured...
Old Apr 30, 2010 | 07:06 PM
nothing_shocking's Avatar
Originally Posted by 98civdx
Agreed with above,
You pulled the entire tranny so of course the oil spilled out. Don't have to pull the tranny to change an axle.
Old Apr 30, 2010 | 07:11 PM
98civdx's Avatar
Master Detailer
no ****,
when i pulled the axle out it poured, we were removing tranny cause it was shot, axles have to come out for that.
CEMAYHALL's Avatar
Agreed with above,
Reading Comprehension... He said "only a couple of drips" referring to when the axle is being changed, not a transmission...
Old Apr 30, 2010 | 07:13 PM
98civdx's Avatar
Master Detailer
oh god not a another one, WHEN I PULLED THE AXLES TRANNY FUILD POURED OUT!
the damn thing was almost empty when we pulled it.
Then I want to say his tranny was over filled...
OP: You shouldn't lose much fluid changing an axle. If you're worried about it, just go buy a quart of whatever you have in it now and if you don't need it, take it back.
Old Apr 30, 2010 | 07:16 PM
B18C5-EH2's Avatar
Former Moderator
Loved
If the proper amount of fluid is inside the tranny then:
- Automatic - should not spill any fluid when pulling an axle
- Manual - will spill some, but if you look the fill hole and diff hole where axle goes are very close level wise
If fluid comes pouring out then someone out that much extra fluid into the tranny. If fluid comes out of an auto tranny when popping an axle out then someone really overfilled that junk.
To answer the question:
If it's a manual tranny I'd drain it all out and use only Genuine Honda MTF. If you already have that then I guess try and save it for reuse.
If it's an auto and it has Genuine Honda ATF-Z1 then yes try and reuse it if you wish.
It's less than a week old anyways, right?
Old Apr 30, 2010 | 07:26 PM
98civdx's Avatar
Master Detailer
Originally Posted by CEMAYHALL
"Oh God" If you would have stated that in your post, you wouldn't look like incompetent retard...
P.S. Check the post times Boy Genius...
Forgive me for thinking people would know what i meant.
Old Apr 30, 2010 | 11:04 PM
peekeesh's Avatar
forgot to mention my car is stick shift.
@Blahblah718293, the axle wasn't replaced because I wanted to do it my self. didn't wanna pay the mechanic for something I can do.
btw, i replaced the axle because i hear clicking noise when turning right. the axle's outer boot is torn as well. so yeah am done replacing the axle, but how come the noise is still there? my car is lowered by 2" and I don't know if it can break newly installed axle that fast. any ideas what to check?
Old Apr 30, 2010 | 11:15 PM
Linked's Avatar
you guys dont mention how the car was elevated ... (duh)
if your using jack stands, the car will lean backwards, and tranny fluid level will be higher on Axle side of tranny
if using a lift the car is level and fluid wont be as high on axle side as it would be using jack stands
Old Apr 30, 2010 | 11:37 PM
riceboy669's Avatar
Hmmm I've changed both of my front axles in my ek and my prelude and did not get any oil spill.
Old May 1, 2010 | 04:40 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Believe it or not it's entirely possible to get a bad axle right out of the box. I've installed brand new, not reman, axles that either clicked when turning, or the inner joint was loose and it vibrated under acceleration.
Old May 1, 2010 | 01:15 PM
peekeesh's Avatar
I see. gonna try replacing it again next week and hope the clicking will go away. thanks..
Old May 1, 2010 | 01:21 PM
98civdx's Avatar
Master Detailer
happend to my friend with shucks axles, one clicked worse then the old one right out of the box.
I doubt a 2 inch drop will hurt axles, plenty of people lower without any issues.
neil09
Apr 23, 2024 10:31 AM
G00BER
Transmission & Drivetrain
Dec 28, 2010 07:46 AM
baller status
Jul 19, 2009 08:16 PM
OOOtony
Apr 22, 2009 10:50 PM
EG6_DREAMS
Aug 20, 2007 05:17 PM
