Seeker Wing troubles with Alex Brackets(replica) EK hatch owners help
Hey I have a problem installing Alex Brackets replica on my Seeker wing.
Here is where I bought the Alex Brackets..
http://cgi.ebay.com/ALEX-BRACKETS-st...item2a00136637
when I asked the seller if it would fit my wing he said it would fit a ek9 CTR wing.
so if the mounting points are right it would fit.
after attempting to install these brackets the mounting points were accurate and the brackets fit for both sides, but I believe that the angle of either the base or the actual wing is off so here is some pics of the install.
Im sure that the angle of the mounting point is what threw off the brackets because when I allign one side to fit the other side is almost off by an inch.
Im pretty sure that I have a seeker replica, but what is going on? the wing? the base? or brackets?
any help, suggestions, tips would be appreciated. thanks.
I was thinking about bending the both brackets to angle it but still hesitant on that idea.
just slot the top bracket and bottom bracket that way the come closer together. If not just get some spacers from lowes and longer bolts. Add spacers and bolt together, they sell nylon ones so you can cut them to fit.
http://www.lowes.com/pd_136887-37672-880426_0_?productId=3012426&Ntt=spacers&Ntk=i_prod ucts&pl=1¤tURL=/pl__0__s?newSearch=true$Ntt=spacers
how would I use this? add it to the bottom to correct the base angle? or?
btw how would i slot my brackets?
thanks alot for the help!
ohh.. hmm i think getting it slotted is a much cleaner option, but who can slot these brackets for me? a shop?
i got a weld grinding tip for my dremel. Its a cone shape. Im pretty sure it would slot them. Id deff try to slot first, but if all else fails, using spacers would work for the time being.
Or use a drill press, and keep slotting the hole with what ever size bit you need.
i bought some brackets from Tegiwa also. when i put them on there was a inch gap EXACTLY like ur pics. i switched them around and then they fit perfectly, i can tell in ur pics u have them on wrong. hopefully u havent drilled in them yet or anything lol
