98 civic ex b16a cranks but does not start
Old Apr 29, 2010 | 02:05 PM
emgjsdk1's Avatar
Default 98 civic ex b16a cranks but does not start
like the title says, it cranks and cranks and cranks fine but does not start. i pulled the fuel line from the bottom of the fpr and only a few drops of fuel came out, when you turn the key to the on position engine off, the fuel pump doesnt prime and im not getting any spark help
Old Apr 29, 2010 | 05:38 PM
knightsef-eg's Avatar
Default Re: 98 civic ex b16a cranks but does not start
ok first of all....is the timing right?
are the grounds all hooked up...
did you go with a new cap and rotor or check if its ok?
new plugs and wires?
did it run before? have you checked for vac leeks ..
what are the specs... did you swap it or buy it ? right ecu there are alot of things that might be causing this problem...
start with this...
1.. check timing,
2 ..check the plugs and wires/cap and rotor...
3.. check your grounds and fuses...
4.. check for vac leeks and any connections broken or off
Old May 16, 2010 | 09:56 AM
emgjsdk1's Avatar
start with this...
1.. check timing,
thanks for the help, i ended up fixing the problem it was the engine harness at the driver side shock tower was a little loose and corroded.
playa24vtec
19
Nov 5, 2013 09:19 AM
Dc2 Strogg
Oct 25, 2011 04:07 PM
ej1kid10
Jan 1, 2011 03:44 PM
garrettrauch
Aug 31, 2010 09:44 AM
plantmylotus
10
Oct 14, 2008 10:49 AM
