why does my cluster read hot
Old Apr 28, 2010 | 08:42 PM
phoxking's Avatar
Post why does my cluster read hot
my 96 ek has a 16 motor n when we turn on the car it goes to hot in 2-4 mins.. i replaced the radiator but its still hot n we flushed it. the feed n radiator is hot but the coolant isnt hot at all while on for 2-4 mins@running temp? could it be the cluster isnt calibrated or my thermostat? help me ht!
Old Apr 28, 2010 | 08:48 PM
em1pusha99's Avatar
Default Re: why does my cluster read hot
oh man, dude pressure test the system, find leak, fix leak, problem solved. or figure out if your electric system is working, such as cooloing fan. make sure it's turning on. if all that checks out, then i would say maybe you have an issue with your cluster, kinda un likely though.
Old Apr 28, 2010 | 08:58 PM
joel96sedan's Avatar
well considering a thermostat is only like 5 bucks, try that to see if it works, if not, then you're only out of 5 dollars. then its probably a leak somewhere if not your thermostat, is your car idling okay?? if it sounds rough then it might be your headgasket. just as long as you're car isnt using alot of coolant, its most likely a simple fix such as a hose leak or thermostat
ALDJ253
Mar 4, 2014 03:42 AM
faSHOwidIT
10
Jun 13, 2006 10:47 AM
HondaHemi
Apr 30, 2006 10:49 PM
Honcivic97a
Dec 16, 2004 01:20 PM
5genhatch
Nov 30, 2004 08:41 AM
