A little Alternator advice?
Old Apr 28, 2010 | 05:19 PM
siVix's Avatar
Default A little Alternator advice?
'98 Civic with power steering, unless I'm missing something obvious it looks like the axle has to come out to remove the alternator? On my other '98 with no power steering you can maneuver it out, but for some reason on my PS car no matter what way I turn the alternator there's just no room to get it out. Is there a trick I'm not seeeing?
Old Apr 28, 2010 | 05:23 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: A little Alternator advice?
Had to pull the axle to get mine out, '96 with PS.
Old Apr 28, 2010 | 05:26 PM
RICKSAUTOMOTIVE's Avatar
i'm going to look up the labor time for replacing the altinator. if its really high for an average altinator (about .8 hours) then it may require an axle removal...hang on guys
Old Apr 28, 2010 | 05:29 PM
its 1.2 hours. hang on i'm looking at the removal part..
Old Apr 28, 2010 | 05:32 PM
ok so i'm sure we can skip the duh stuff like he batt cable, radio code, and plugs...oh well we got that N-E-ways
remove the bolts...adjusting bolt and through bolt.....more posts coming
Old Apr 28, 2010 | 05:33 PM
then the belt (another duh thing)....
Old Apr 28, 2010 | 05:34 PM
then pul any remaining bolts holding the alternator in place.....you guys are stuck here huh? hang on....
Old Apr 28, 2010 | 05:36 PM
if necessary, remove the mount bracket bolts, and the upper and lower mount brackets. then remove the alt. and replace it and adjust
Old Apr 28, 2010 | 05:37 PM
and you know the rest
dont see anything unusual except maybe the bracket removal....does this help?
Old Apr 28, 2010 | 05:50 PM
Former User's Avatar
Removing the lower mount bracket is the key to success. This way the axle does not need to be removed.
Old Apr 28, 2010 | 06:32 PM
siVix's Avatar
I sure do appreciate all the responses! I've got the lower bracket out, I guess I just haven't hit that magic angle it needs to be at to get it to slide through.
Old Apr 28, 2010 | 06:43 PM
Did you also remove the splash guard? In addition, you must have the front end on stands not on ramps.
Old Apr 28, 2010 | 07:06 PM
siVix's Avatar
I've got it on jack stands, but still have the splash guard in, it seems flexible enough I can pull it out of the way, I just keep getting hung up on the axle. The more I mess with it the more I think I'm going to have to pull the axle to get the new one in properly anyway. Getting the old one to fall out is one thing, getting the new one seated right and holding it in place while I get the lower bolt through it is another.Thank you for all the great info Ron!
Old Apr 29, 2010 | 03:12 AM
BryanM.'s Avatar
Resident Gearhead
I also could not get it out with the axle in the way, bracket removed too. Pulling the axle is no big deal.
Old Apr 29, 2010 | 07:49 AM
It helps to remove the splash guard because the pathway that the alternator takes for removal is toward the driver's wheel, not straight down past the axle. You could also try turning the wheel right or left to maximize space for the alternator to slide out.
MR_Se7en
Mar 25, 2008 10:04 AM
90silverda1987
Mar 28, 2007 01:47 PM
shiux
Oct 22, 2005 09:30 AM
BloodPressure
13
Jun 30, 2005 10:28 AM
Layziebtnh055
May 3, 2004 12:07 PM
