How do you check ignition timing? I have searched and found no guides for a Civic
Old Apr 28, 2010 | 02:42 PM
Juans_MX3's Avatar
Default How do you check ignition timing? I have searched and found no guides for a Civic
Want to check my ignition timing, are there any guides around here on how to do this step by step on a 95 Civic EX?
Never had to do one before. So I would like to learn on what tools I need and how to do it.
Thanks
Old Apr 28, 2010 | 02:46 PM
Former User's Avatar
Default Re: How do you check ignition timing? I have searched and found no guides for a Civic
Old May 3, 2010 | 05:25 PM
Juans_MX3's Avatar
Originally Posted by RonJ@HT
So here is a stupid question. Where is the timing light suppose to be pointing at. From the top of the engine or from where the tire is?
My Haynes manual (i think its a Haynes) says to point it from the top.
But I dont see nothing from there.
Also, I dont see none of the timing marks on the crank pully. The crank pulley also has some surface rust.
I might think about trying to scuff it out.
Old May 7, 2010 | 05:23 PM
Juans_MX3's Avatar
Ok, I was able to adjust my timing with a timing light, but I have a question. How do you guys know that your timing is off by a certain amount of degrees?
The way I adjusted my timing is I did what your guys did with a timing light and by rotating the distributor. I pointed the timing light from where the A/C is at, to the timing marks and I looked at the timing marks from the top of the engine.
I seen 3 marks, and then the 2 marks (TDC, I believe) and I tried to line them [the 3 marks] up the best I can with the timing "pointer" thing that kind of sticks out.
Like shown on the picture.
I know it says to point the timing light towards the "pointer", but does it mean to do it from right above the pointer? Because I tried pointing to it from directly the top of the pointer and I couldnt the timing marks. But when I did it from an angle (from the A/C pulley area), I was able to see the timing marks.
Last question, what degree do you guys recommend to time the car so it passes the idle HC test?
koa
May 24, 2018 12:05 AM
1mistashank
May 29, 2009 08:17 PM
chengrazng
Aug 23, 2007 11:03 AM
nick32
Dec 28, 2005 01:48 PM
90teg
Aug 26, 2003 01:45 AM
