2 cylinders low compression
left to right 215-210-100-90
bent valve?jumped time?
It would run in limp mode,real weird.got to get the comp fixed first i know.any tips to pul the head.This is a jdm h22a swapped 99 civic
I have a leak down tester
Gotta do a leakdown test to see what the problem is, but the most common problem is valves. Before pulling the head after the leakdown test, check the valve adjustment first.
If it's cylinder 1&4 or cylinders 2&3, chances are the timing belt broke sometime in the car's history.
Im gonna do a leakdown its 1 and 2 that r low,the belt is nice and tight
anyone else?Any good p&p guys that work cheap?Just want a good n/a build
dplatt
Dec 31, 2002 01:24 PM
